When changing Brake pads on a 360 | FerrariChat
Discussion in '360/430' started by djastral69, Jan 27, 2010.
  1. djastral69
    djastral69 Formula 3
    1,896
    Fl
    David
    When changing brake pads on my 360 with 13K miles. Do I change the rotors as well? The pads are not all the way down but I thought I'd nip it now.
  2. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Check for rotor thickness, uneven wear grooves and cracks. Minimum rotor thickness is usually stamped at the edge of the rotors.
    No need to change if all is within spec. I doubt at 13K you need to change the rotors, unless there were some unusual usage and wear.
  3. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,459
    can the rotors be resurfaced if there within specs?
  4. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Not unless there's reason to do so! Are you getting vibration when you apply the brakes?
    Minimum thickness is specified at 26mm
    Max Tolerance for flatness is 0.025mm but they could be resurfaced if that's exceeded.
    Unlikely they need replacement or resurfacing if they feel ok in use.
