WHEN I START THE 355F1 ENGINE RPM GOES TO 2500 | FerrariChat
Discussion in '348/355' started by WIND, Oct 7, 2008.
  1. WIND
    WIND Karting
    132
    LIGHTHOUSE POINT,FL
    MARK KAHN
    HI GUYS
    MY 1998 355F1 SAT FOR I WEEK
    START THE CAR THIS MORNING SEEMS LIKE THE EXCELLERATION STUCK.....
    I REMOVE THE CARPET...START AGAIN.....RPM JUMPS BACK UP @ 2,500 RPM
    THIS IS THE FIRST TIME THIS HAPPENS
    I CANNOT DRIVE OFF ...RPM REVIVNG TOO HIGH......
    IS THE CABLE STUCK.....OR IS THERE A SENSOR SOMEWHERE
    ANY ANSWERS
    THANKS
    MARK...FT.LAUDERDALE AREA
  2. Tom_C
    Tom_C Karting
    Feb 20, 2008
    233
    Raleigh area, NC
    Tom C
    #2 Tom_C, Oct 7, 2008
    My 348 did that after doing some work to it. I thought I had pinched the throttle cable some how, but everything checked out. Started mine about 3 times with it doing that, before thinking about hitting the gas real quick, just to see what happened... I blipped the throttle once, and it settled right down. No more problems, and startup was back to normal. Hope that helps!
  3. TheRye
    TheRye Rookie
    Oct 4, 2008
    48
    Reston, VA
    Check your foot. It's hard for me to take it off the gas pedal. 8mpg at the pump proves my point.
    Seriously though, on some of my past sports cars, there was an idle screw that you could mess with to lower the idle RPM. I've also run into surging idle when there is a loose vacuum hose. I'm not sure if these cars feature either of these issues, but it's something to toss out there.
  4. WIND
    WIND Karting
    132
    LIGHTHOUSE POINT,FL
    MARK KAHN
    HI TOM
    I TOOK YOUR ADVICE....PRESS THE AXCELLERATOR PEDAL HARD ....BACK & FORTH
    FIX THE PROBLEM...ENGINE WAS REMOVE & REPLACE...TIMING BELT CHANGE
    THE SOCKET END OF THE CABLE ....MIGHT HAVE SLIPPED OUT OF THE PEDAL
    THANK U GUYS FOR LISTENING
    MARK KAHN
    QUICK FIX
  5. Tom_C
    Tom_C Karting
    Feb 20, 2008
    233
    Raleigh area, NC
    Tom C
    Glad to know it was something simple. :) I just wish I knew why they revved like that....
