When to check oil in an F355B? | FerrariChat
Discussion in '348/355' started by Hotzos, Feb 13, 2005.
  1. Hotzos
    Hotzos Formula 3
    Oct 19, 2004
    1,060
    Parker, Colorado
    Mark Gomez
    Okay...please excuse the novice questions but if the car has been sitting for a few days and you want to check the oil, how long do you let the car idle before you shut it off and check the oil level?
    If the car has not been run, and it is cold, how much oil if any can you expect to see on the dip stick?
  2. 38 Off
    38 Off Karting
    Nov 4, 2003
    247
    Pace, FL
    Phil Crain
    Check it with the temp at max, right after you pull back in the drive, etc.
  3. Rifledriver
    37,087
    If you can hold the oil cap in your hand it is not hot enough.
    None. It will all (but a quart or two) be in the sump.
    There is only one way to ck oil. Hot, right after shutdown.
  4. Hotzos
    Hotzos Formula 3
    Oct 19, 2004
    1,060
    Parker, Colorado
    Mark Gomez
    Thanks guys.
    To confirm, you check the oil with a hot engine and the car turned off, without screwing the cap in. Correct?
  5. Higgins23
    Higgins23 Karting
    Jul 16, 2004
    179
    Europe
