when topping off eng oil,do you top off while running ? | FerrariChat
Discussion in '360/430' started by blkdiablo33, Jul 16, 2010.
  1. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,453
    when topping off engine oil do youguys top off while running than recheck level,or do you shut off add oil and than restart and ck?
    thanks
  2. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    leave running. just remember that cap is HOT. Use a rag to hold it..
  3. andrew911
    andrew911 F1 Rookie
    2,894
    Northern NJ
    #3 andrew911, Jul 16, 2010
    I'm sorry to repeat what has been said elsewhere, but I'll add this anyway- make sure you have the oil fully warmed up and the car is level- it's amazing how much the oil expands vs. checking with a cold or coldish temperature...you do not want to over fill- I would aim to get the level somewhere between the max and min line or 2/3s up from min to allow some expansion room. It's a pain in the butt because the oil lid is so hot and your reaching over an even hotter muffler, but it's a bigger pain in the butt to use a turkey baster as a siphon to pull out hot oil that was overfilled (my car was a little more than a quart overfilled when I got it and that's what I had to do)- you don't want to overfill because it can lead to bigger problems like messing up the intake or maybe even getting up to the mass airflow sensors (I had to replace a MAF and I wonder if it was due to an overfill prior to my ownership or the overfill when I took ownership).
    I'm always very careful as I remember a guy on here (forget if he had a 355 or 360) talking about how he had a nice burn mark on his leg in the shape of two muffler outlets from his tubi! :)
    Oh to your original question, yes you can add with the car running- probably easier that way in fact.
  4. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    How much is oil will take a min reading up to the maximum?
  5. blkdiablo33
    Jul 12, 2004
    4,453
    i checked my oil and it was low,so i added 1/2 qt and now its right between min and max.i added while eng running and after a good drive.
    thanks for all the feed backs
