I HIGHLY recommend adding a bolt-on supercharger. My Mondial-8 was pretty sluggish until I added some extra horsepower. Now it's as fast as a 348! Carl's kit has every part in it you need and comes with a great installation manual with lots of photos. Check it out here: http://www.928motorsports.com/parts/ferrarisupercharger.php
I had mine repaired by a local clock repair shop for $50. Check your local phone book. (Just DON'T tell him it's for a Ferrari ) He just changed the lense on mine.
Stuart, I just sent you a PM, have tried unsuccessfully 4 times during the past 2 months to order some small parts for my 1975 308GT4. Hope you can help.
Bavarian autosport had it for $39.95. Part number is 61311363459. It fits a BMW 320i, 6and 7 series to 82 and 5 series to 88.
can anyone help ... am having problems locating a proper GT 4 toolkit . One with the plug spaner and the carb key . .... many thanks
I recently received a parts list from Verell's Unobtainium Supply Co. I'm absolutely amazed at the large amount of NLA parts Verell now sourcing, also, he repairs column(headlight) switches & targa top latches! Unobtainium doesn't have a web site yet. So I thought I'd post a list of the 'unobtainium' he supplies here where people are likely to find it. I didn't put prices in the list as they could change over time. Verell is constantly adding products, so if you don't see something here, send him eMAIL: Verell(at)UnobtainiumSupply(dot)com Unobtainium takes PayPal sent to: Orders(at)UnobtainiumSupply(dot)com Or, you can send checks or money orders made out to: Unobtainium Supply Co. 523 Longley Rd. Groton, MA 01450 Unobtainium Supply Co. Part Description Used On ---------------- ------- Bezel, Lever Black, Unbreakable 308GT4, others Bezel, Lever Chrome Unbreakable Al 308GTS/B,400, others Cover, Seat Belt Bracket Style A 308, others Cover, Seat Belt Bracket Style B 308, others Emblem, '308' Black Chrome Plastic 308 Emblem,308 Black Plastic 308 Knob, Mirror Switch 308 QV Twist Knob, Headlight 328 & Mondial Knob, 308 Headlight 308 Knob, 308GT4 Headlight 308GT4 Knob,Disc shaped 308,400, others (Temp, vent, choke, & switches) Latch Housing,Boot 308/328 Latch Housing,Bonnet 308/328 Mirror End Cap, Rear, rounded, US Spec. US 308/328 Mirror Front Cap, Trapezoiodal, US Spec.US 308/328 Boot Prop Flex Joint 308 Radiator Bleed Thumb Screw 308, 328 others EZ Bleed Bolt, Thermostat Housing 308, 328 others (Thru drilled to bleed without removing!!!) Shift Shaft Bushing, Delrin (Replaces SilentBloc) 308,328 Cam Gear Locking Tool, 2V 308, Mondial 2-Valve QA1 Shock Adapter Bushings - 4 wheel set 308, & 328 before s/n: 76626 Paper Weight, QA1 Stretched Eye Targa Top Rubber Boot 3x8 GTS Targa Top Latch Rubber Nose restoration:Remove any residue of old rubber nose, mold a new polyurethane nose. 3x8 GTS Column(Cluster) Switch Parts ---------------------------- Description Used On Column Switch Brass U-shaped Contacts 308,328,Mondial, others Stalk, Headlight (Chrome Plated shaft) 330 GTC, others Stalk, Turn Signal (Chrome Plated shaft) 330 GTC, others Stalk, Wiper (Chrome Plated shaft) 330 GTC Stalk, Turn Signal (Black shaft) 308/328 Stalk, Turn Signal (Satin Aluminum shaft) 265 Dino/ 308GT4, others Stalk, Wiper (Black shaft) 308/328 Stalk, Wiper (Satin Aluminum shaft) 265 Dino/ 308GT4, others Column Switch Services ----------------------- Services for 265 Dino/ 308/328/Mondial/365 GT4/ 330 GTC, other with similar switches: Stalk rebuilding Service (Mold 1 new knob or contact arm on a stalk) You remove/install stalk. Stalk rebuilding Service (Mold 1 new knob or contact arm on a stalk) We remove/install stalk. Column Switch Full Service & Stalk Repair: Disassemble, check out, clean, remove tarnish & lube contacts, lube moving parts, polish knobs, clean lettering & icons. If necessary mold 1 new knob or contact arm on a stalk. Column Switch FullSvc w/new stalk:As above, but includes one new Wiper or Turn Signal stalk. Additional Column Switch repairs are available, they will be charged on a time & materials basis. When my right vent control bezel broke, all I could find was used plastic pieces, at ridiculous prices. After receiving two new bezels from Unobtanium, I was so impressed with the quality and finish, I bought the rest of the set. They are WAY better than stock. The quality is at a minimum equal to stock parts and in most cases a superior part. Communication and price are also first rate. There is also a wild rumor that he is working on “noweightium” Thanks Verell, chris
From another thread, thought I would post the link to the thread/post in case anyone needs a reference. This is for other AGM (not lead acid) batteries. http://www.ferrarichat.com/forum/showpost.php?p=137514225&postcount=40 James in Denver
I'm not sure if you'll get this msg but anyway, I bought the '79 308 from downeast NC. A sweet deal. Thanks for your help! Steve G. p.s. Darryl talked to me about this one also.
Does anyone have the e-mail for Ferrari UK the one I had and Ferrari SPA sent me no longer work. Does anyone know what's going on there, who still working their and their phone numbers now that they are off the owners site?? Thanks Rob
Classic Parts in Egham are still fine and in fact are due to deliver an order to me today - I dealt with Martin whose fax is + 44 1784 436303 - http://www.ferraripart.co.uk/Contact.aspx http://ferrarichat.com/forum/showpost.php?p=137372649&postcount=33
I need part no 60044401 X 2 moon shaped dash vents, for my 79 308GTB, Tried all usual places, Rytlands, McCann, Ricambi, Ferrari u.k. but seem out of luck, i suppose they are very rare!
Brand new LHD and RHD floor undertrays as per original for 308's GTB/S are available from Forza Automotive email Gerry - gerrydino@optusnet.com.au Cheers MG
also try www.ferrparts.com for hard to get parts new and old,every part I ever needed ferrparts has come through for me,and ricambi is great to
T. Rutlands has good service/availability.. Also try Motion Products www.mpirestorations.com a-lot of vintage parts Cheers,
Thought I would post some links for cloth braided fuel hoses for a U.S. 85 308 QV for anyone interested. just did all of my fuel, smog, and vapor hoses recently and used a variety of sources to also retain the cloth covered hose. Here are some links I used for cloth covered hoses in a variety of sizes: 19mm- www.hiperformancestore.com/hosebyfoot.htm 7mm- www.autohausaz.com/ 5, 7.5, 10, 15, 19, 22mm- www.newcoproducts.com/new/cohline/hoses.php 6, 9mm- www.pelicanparts.com 16mm Cavis clear hose, 20mm cloth braided hose- www.italiancarparts.com/parts/308.html#hoses I used non-braided 5/8 fuel hose on the vent tube connectors on the firewall, cloth braided 7.5mm for the cloth vent hose which runs the length of the firewall, and Dave Helms hoses for the filler neck, tank to fuel pump, and crossover hoses at the bottom of the car between the tanks. Oh, and lastly I bought new steel braided plastic lines from Verrell on the board. I used the different sources for availability and costs. Hope this helps!
This is the map pocket on the back of the passenger seat that has a key lock. See this thread prior to bidding on e-bay http://www.ferrarichat.com/forum/showthread.php?t=300694
See if this source is still available. " I use magna flow 28 inch muffler 2 1/2 inlet + outlet. Its all st/ steel, and bolts to OEm muffler brackets, $900 USD + shipp will be about $150. Also have 360 style keys to suit 308 new repo uncut, $90 + $30 shipp, and new dash vents $400 + shipp. If you need anymore in fo drop me a line." Cheers Rizzo rizzop@optusnet.com.au Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
