Where can you purchase caliper rebuild kits for a 360? | FerrariChat
Discussion in '360/430' started by X-TNSIV, Jan 7, 2014.
  1. X-TNSIV
    X-TNSIV Formula Junior
    May 2, 2007
    347
    Irvine, CA
    Allen
    I was considering having my brake calipers powdercoated red and wanted to know where I could source caliper rebuild kits?
    and does anyone have a DYI write-up on how to rebuild them?
    thanks!
  2. RedTaxi
    RedTaxi F1 Rookie
    3,310
    New Zealand
    Glen
    I'm sure Brembo do rebuild kits.
    Basically just pop new seals in so long as there is no corrosion in the bores.
    Unless they are leaking I would say get them powder coated and re-install them. They should be fine.
  3. X-TNSIV
    May 2, 2007
    347
    Irvine, CA
    Allen
    I contacted Race Technologies (US distributor for Brembo) and they said the OEM Ferrari Brembo seals are proprietary to Ferrari, but I figured someone would sell a rebuild kit. I know Girodisc did at one point, but I don't know if they are still in business.
    And I'm sorry, but I have never disassembled calipers before, but I believe you are saying is that all I need are new seals from Ferrari?
  4. Ricambi America
    Sponsor Owner
    Call Martin Meade @ Griodisc.
  5. tazandjan
    39,057
    #5 tazandjan, Jan 7, 2014
    You would need 4 38 mm seals and 4 42 mm seals and from Ricambi, about $850. Check back with Brembo and see if they will not sell you generic 42 mm and 38 mm seals if you really want to reseal the calipers.
    If the calipers are not leaking, I would not bother. The caliper can be masked so no paint gets where it does not belong and low temperature powdercoating should not bother the seals.
    Incidentally, my calipers are repainted with normal auto paint and clear coating. Works great. The calipers do not generate enough heat to bother the paint and the clear coat goes over the decals.
  6. X-TNSIV
    May 2, 2007
    347
    Irvine, CA
    Allen
    Thanks for the info Taz.
    This may be the easiest option as I do not think my powdercoater wants to deal with the brake fluid potentially contaminating the work. They said they wanted to have them chemically stripped prior to powdercoating. I wonder if that is truly necessary or not.
    Do you know where would be the best source for decals?
    and does anyone have any experience with a Red that is a close match to rossa corsa?
  7. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    Having had my calipers in bits I can confirm that there are no special Ferrari specific seals or pistons going on here on Brembo calipers. It is just that Ferrari chose not to sell them separately [like a lot of other parts]. Its likely to be so they can make more money selling complete calipers and pads...
    I personally popped out the pistons (and you can pretty much do this on any caliper) and used an accurate measuring tool to confirm diameters of both the pistons and the seals.
    As it happens for CS / F430 / Scuderia options Hills Engineering sell complete replacement pistons and seals replacing the nickel coated pistons (which corrode when scratched by dirt), they may also sell equivalent for 360 so worth checking with them.
    If you already know the dimensions (Taz posted 38mm & 42mm) a simple google search on Brembo Caliper Piston seals will reveal many choices costing about $15 per seal.
    :: #1 Race Specialist in The World :: » Brembo
    My full CCM caliper rebuild and refresh was done in my project thread, calipers starting here;
    http://www.ferrarichat.com/forum/360-430/158419-360stradale-6-speed-manual-conversion-29.html
    Good luck!
  8. tazandjan
    39,057
    #8 tazandjan, Jan 7, 2014
    Allen- I found mine on the internet (Ferrari brake decals) from several sources and bought about 50 so I could figure out what size I needed for my aftermarket calipers. The OEM decals are about 3" or a little less, so you can search for that size. Jason Godsil, one of our sponsors from Exotica Motorsports, offers a Ferrari caliper paint and decal service if you buy Brembo upgrades from him. He might be willing to sell you some decals. OEM was black lettering on all colors except for black calipers, which used white. We have all the OEM paint codes for the calipers if you need them. Images are from the 575M Scaglietti options catalog, which included some 360 and 456M options for no reason I can think of.
  9. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    #9 FerrariDublin, Jan 7, 2014
    I have a set of refurb seals which I haven't used yet so I cannot say for sure that they are a perfect fit but the cylinder diameters are correct. The cost per caliper is less than a single "Ferrari" dust cover. They're for a Fiat Coupe - manufactured by Budweg
  10. m5guy
    m5guy Formula 3
    Aug 17, 2008
    1,627
    Ventura, CA.
    Greg
    ^ This. A knowledgeable source says that the Budweg pressure seals are high quality and used as standard equipment on at least 1 manufacturer's performance brake systems.
  11. X-TNSIV
    May 2, 2007
    347
    Irvine, CA
    Allen
    I contacted Girodisc and they do have pressure seals and dust boots available for our brake calipers
  12. LorenzoR
    LorenzoR F1 Rookie
    Taz, old thread i know, but you mention you have all the paint codes for the calipers. I need yellow. I noticed when i was searching eurospares for ccb calipers that there are 2 ellows. Description on one part number says yellow, on another it says modena yellow. Are there 2 different yellows? If so how do you know which color to get. Thanks
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    See my CCM caliper thread down the page re 430, will be similar. Seal kits look up motorbike caliper seals
  14. tazandjan
    39,057
    Lorenzo- There was only one yellow, but there was also a gold at one point. PPG code is 84028 and the color is Giallo Modena.
  15. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
  16. LorenzoR
    LorenzoR F1 Rookie
    Ok Thanks Terry 84028 it is
  17. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,754
    England
    Mark
    Gents, there is a late and early yellow. One is more of a mustard colour, and one is more vivid. The change was around the F430 era.
    I don't have the codes as I went from the powder coat colour chart.
  18. LorenzoR
    LorenzoR F1 Rookie
    #18 LorenzoR, Dec 19, 2021
    Thanks Mark. if possible can u post a pic of the chart
