Where do I send my clutch disc to get refaced? | FerrariChat
Discussion in 'Technical Q&A' started by jm3, Jun 29, 2007.
  1. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    F355: some of you guys have some good recommendations on companies that reface the clutch discs with an alternate material.
    I have had this done already, and have been happy with it. I would like to try a new company for my next clutch, so can you please give me your recommendations. PM is ok too.
    Thanks, Jay
  2. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,397
    Dumpster Fire #31
    SMG
    Jay,
    contact Mike down in OC, he resurfaces the disks as well. even has the V12 pressure plate redone with more clamp force if needed.
    ferrari service of costa mesa; 949-548-9541
  3. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    #3 PAP 348, Jun 29, 2007
    If you're real keen Jay, you can get something like this. :):)
    This is my 348 clutch, made here in Australia. Bulletproof. Can be made to suit 355. ;);)
  4. fatbillybob
    Aug 10, 2002
    29,166
    socal
    Nice pap! How was it done? Did you use the OEM center. have a plate cut. kevlar buttons riveted onto plate challenge style?
  5. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,879
    Atlanta
    John!
  6. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Exactly right mate. :):) VERY strong clutch. Bulletproof on the street and can handle abusive track days also. :):)
    Pressure plate also has more clamping force. I forget exactly how much HP/Torque the clutch can handle, big numbers though. ;)
    I also forget how much more clamping force the pressure plate now has. :)
    Clutch was made for me by ferrarifixer here in Aus. :)
  7. Dong Juan
    Dong Juan Karting
    Jun 28, 2007
    57
    South
    Dong Juan
    Centerforce will do kevlar pucks on your existing disc, assuming it is in serviceable condition. The kevlar grips very well too, you may not even need a stronger pressure plate.
  8. Llenroc
    Llenroc F1 Veteran
    5,526
    Colorado
    Vern
    I wouldn't recommend using kevlar for your clutch. It's a great material, almost too good, it is so wear resistant that it will wear your flywheel out before the clutch disc goes. If you haven't priced a new flywheel lately you should check that out. You can buy several std material clutch discs for the price of one flywheel and presure plate. Regards, Vern
  9. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Yeah, thats the downside to them. ;);)
  10. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    also check out clutchmasters, I heard they can do it too. I'll be sending mine out soon too...
  11. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Tell Phil I say high the next time you talk to him. It would be nice to have him back around again.
  12. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Been down that road, $3000 easy!
  13. chrisx666
    chrisx666 Formula Junior
    Dec 6, 2004
    562
    YorkshireUK
    Chris B
    #13 chrisx666, Jun 30, 2007
  14. Llenroc
    Llenroc F1 Veteran
    5,526
    Colorado
    Vern
    I agree looks like just the friction part which is fine, but as I was saying look at the price compared to the disc. You can buy 8 discs for the price of 1 flywheel and disassembling/assembling the 348 and 355 flywheel is alot of work ie; not the same as the good 'ol chevy small block. The 348 or 355 don't produce enough torgue or hp to warrant a higher than stock performance clutch disc or presure plate. Just MHO. Although I will say Pap's parts look cool, haha. Regards, Vern
  15. f355spider
    f355spider F1 World Champ
    18,053
    Closer to $3900 at Ricambi...and around $4400 at FNA dealers. Insane.
  16. PAP 348
    Dec 10, 2005
    100,224
    Pap
    I know you thats all you really wanted to say Vern! :p:p
  17. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Will do for sure man. Would be be cool to have him back alright! :):)
  18. PAP 348
    Dec 10, 2005
    100,224
    Pap
    Talked to Phil just before Ernie and he told me to say hello to you. :):)
  19. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    14,034
    MO
    Omar
    Can you get a custom flywheel also in kevlar as well to compliment?
  20. Llenroc
    Llenroc F1 Veteran
    5,526
    Colorado
    Vern
    Hmmm..interesting idea, but I don't think that material is conducive to the type of mechanical abuse(too brittle) it would receive. Also the flywheel generally needs to have some weight to it for inertia reasons. Although since they are using ceramic material in brake discs that might work as a flywheel but again it might be to light for street use. Regards, Vern
  21. Auraraptor
    Sep 25, 2002
    14,034
    MO
    Omar
    Interesting, thanks for the insight.
