Hi Guys, Any idea where these go? I was cleaning brakes the calipers were off. While using compressed air around the wheel area these 2 items were rolling around on the ground the front air dam is off the car but nothing up there seems to related? Any ideas, they are clean so they must be behind under or hidden. No this is not a quiz. Thanks crash Image Unavailable, Please Login
Look like grommet inserts used on the air cleaner boxes to bolt them down. I have taken the front completely off on a 355 and cant remember those pieces. Also check to see if they do not belong to the pipes running from the front to the back in the tunnel area. could be the tie downs that holds the pipes in place. They are half crescent plastic pieces I think have metal inserts and held in place by 10mm nut.
