Where do these parts go? | FerrariChat
Discussion in '308/328' started by jonesdds, Mar 7, 2010.
  1. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    SB,CA & Park City UT
    Jeff
    #1 jonesdds, Mar 7, 2010
    Took out my seats a few weeks ago and now they're going back. But I'm not sure where these parts came from, I assume somewhere on the rails. Only a pair so one per chair I presume or do they both go only on one side?
    Thanks for the help. I've got to learn to document better when I take things apart!
    Also, which side of each seat do they go on, outer or inner, and front or rear of chair
    Jeff
  2. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,032
    My old Lancia had parts like that to limit the seat travel on the rails. I can't remember if both were on one rail to limit fore / aft travel, or both on the rear to control push back distance etc.
  3. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    One goes on each side, under the rear mounting bolts, to limit seat travel, rearward.
  4. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    inside or out(towards door)?
  5. FF8929
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    I don't recall, but I don't think it matters.
  6. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,321
    #6 Iain, Mar 8, 2010
    Front mounting bolts (not the rears), mine are on the inside -but actually I don't think it matters.
    Without them you could slide the seat forward and right off the runner. Seat travel rearward is limited by the raised part of the floor behind the seats - so not an issue.
  7. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    Thanks that's what I thought from a picture I found posted here. Now I've just got to fix the two stripped bolts, hopefully it's only the bolts themselves, not the mounting spots.
  8. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,321
    #8 Iain, Mar 9, 2010
    If its the mountings you are going to need to drill out the rivets to remove the fibreglass floor under the car - could be messy :(
    An alternative approach would be to see if you can clean them up with a tap & if not then drill them, & re tap them to take a larger diameter bolt I suppose.
