430 - Where do you run your battery tender cable? | FerrariChat
430 Where do you run your battery tender cable?
Discussion in '360/430' started by iheartf430s, Aug 5, 2024.
  1. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    216
    TN
    Ed
    I got the 430 2 weeks ago, and I'm still learning all the little things about this car (which I absolutely love)
    The old owner (super awesome guy, that's still helping me out) said he ran it through the door, and said many owner run the cable through a cracked window.
    My car has the most amazing leather smell, so I'm reluctant to crank the window and maybe lose this incredible smell.
    But I don't want to create a gap in the rubber seal either.
    What's my best option in your opinion?
    ...or am I overthinking this like I do everything else?
  2. azzurribaggio
    azzurribaggio Formula Junior
    I've done the same for the past 5 years in mine.
    Sent from my Pixel 8 Pro using Tapatalk
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,923
    Central NJ
    Dominick
    The proper way is thru the bottom of the door (according to user manual) ..there is actually a intent in the door sill
    mvaldezf60 and iheartf430s like this.
  4. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    216
    TN
    Ed
    Thanks Dominick. I'll read the Manual for the right spot to run that cable
  5. Zed82
    Zed82 Formula Junior
    Sep 28, 2017
    513
    Sweden
    I ran it through the bottom of the door for years but a side effect is that my top window trim is now disfigured a bit and the rubber surrounding of the side mirror has cracked open where the window meets the rubber. The cable puts a bit of tension on the door and the trim.
  6. Benjamino
    Benjamino Karting
    May 1, 2021
    58
    Dronfield, Derbyshire
    Benjamino Johnson
    I always drop the window a little and drape the cable over it before shutting the door
  7. colorfull
    colorfull Formula 3
    2,336
    Franklin Park, New Jersey
    John Napoli
    Out the bottom over the sill as per the manual
  8. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,018
    NE FL
    Ken
    Same as above. over the bottom of the pass door seal.
    I differ in opinion from many of other users here who wire the tender to the fuse box behind the driver seat. Mine is wired directly to the battery.
    The problem with the fuse box connection is it means if you ever flip the battery cutoff, you're now powering your car with a trickle charger and risk damaging sensitive electronics. That cant happen when connected directly to the battery.
  9. Lola360
    Lola360 Karting
    Oct 26, 2023
    135
    Bay Area, CA
    Connor
    Mine has a tender pigtail hidden in the radiator exhaust vent forward of the front wheel. Makes for easy connection.
  10. JSGAuto
    JSGAuto Rookie
    Aug 8, 2021
    23
    JIM G
    I went to the starter connection, and exited out the bottom of the undertray thru a drain hole. Directly at the bottom of the drivers door....so I see it every time.
  11. oc23
    oc23 Formula Junior
    458
    Rob Yo
    boostedt0y likes this.
  12. jerbear27
    jerbear27 Formula Junior
    299
    CT
    Jeremy
  13. robst
    robst Karting
    Mar 9, 2024
    108
    Houston
    Rob
    I run mine through the frunk.
    I used the Ctek extension, ran it under the dash over tot he drivers side and used and existing hole on the firewall to reach the frunk.
    Works perfect and just have to pop the frunk and plug it in, easy
  14. DutchFerrari
    DutchFerrari Formula Junior
    Apr 7, 2022
    778
    Bollenstreek - Netherlands
    Jeroen
    I run mine through the passenger window :) i just put a microfiber towel on the window and paint so that the wire cant scratch it anymore than it did in the ownership of previous owners.....
    Tender connected directly to the battery ofcorse!
  15. collegeboy
    collegeboy Formula 3
    Aug 25, 2007
    1,371
    Texas and Kaua’i
    Mikey
    Driver's door sill and door and windows closed.
    E60 M5 and FerrfanFL like this.
  16. FerrfanFL
    FerrfanFL Formula 3
    2,256
    Florida
    Ara
    this raises another issue for another post. i leave my windows cracked to let the humidity control/AC take moisture out of the car. Spoken with a few high high end detail guys and they say they see moisture, rust etc on many of the cars they detail due to humidity getting locked inside the cars from no ventilation. They suggest leaving windows cracked a hair. One story of a 288GTO that was stored inside (of course) but had mold growing under the dash.
    collegeboy likes this.
  17. imahorse
    imahorse F1 Rookie
    4,350
    WI
    Dustin
    The windows misalign on their own causing the worn trim if I'm understanding your post correctly. It's a common problem on these cars and would not be caused by running the cable under the door.
    Sent from my toilet using FerrariChat.com mobile app
  18. Zed82
    Sep 28, 2017
    513
    Sweden
    Window and door is perfectly aligned and without issues. Checked by the Ferrari workshop when I discovered it. They also attributed the issue to the cable and it is the thick cable side that goes into the wall. Since then I lower the window a bit.
