where does this clip go on maranello timing gear area? | FerrariChat
Discussion in '456/550/575' started by stevepaa, Sep 21, 2017.
  1. stevepaa
    stevepaa Formula Junior
    Apr 5, 2006
    771
    san jose, ca
    steve
  2. stevepaa
    Apr 5, 2006
    771
    san jose, ca
    steve
    okay, looking around the engine bay i spotted the same clip on the fuel injector railing. The clip holds the injector to the railing. But I am not missing one??
  3. Motob
    Motob Formula 3
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
    Some previous mechanic dropped it, couldn't find it and put on a new replacement clip. It looks like someone was lucky, as that could have gotten caught between the timing sprocket and belt with bad results.
  4. fatbillybob
    Aug 10, 2002
    29,026
    socal
    Brian,
    It seems like you are steping up your posts. I'm glad to see it. Thanks for your time!
  5. stevepaa
    Apr 5, 2006
    771
    san jose, ca
    steve
    I had to interrupt my belt replacement process to fix the flywheel lock. While the piece was at machine shop, I started to replace the hoses with Scuderia Rampante hoses and so this injector clip likely fell down from the water pump back lip when I wiggled the water pump out of its position.
  6. JimEakin
    JimEakin Formula Junior
    989
    Mountain Living
    Jim
    Man, are you lucky that that didn't dislodge and mess up your timing belt, taking the top end of your engine with it.
  7. stevepaa
    Apr 5, 2006
    771
    san jose, ca
    steve
    I am pretty sure it was in the valley area between engine banks resting against the water pump which blocks that end of the valley and when I wiggled the water pump out I moved it and it fell down, otherwise I do not see a path for it to get where I found it.
