348 - Where is my air oil separator? | FerrariChat
348 Where is my air oil separator?
Discussion in '348/355' started by Bee Jay, Jul 28, 2025 at 11:01 PM.
  1. Bee Jay
    Bee Jay Formula Junior
    Apr 14, 2004
    751
    Lompoc, Ca.
    Bernard E. Jones
    Hi guys. I'd like to re-introduce myself. My name is Bee Jay and I have a 1992 348ts. I used to be very active on this forum about ten years ago. Since then I bought a 2013 427 Corvette Convertible, and a 2022 C8 Corvette Convertible. So I non opped the Ferrari, and put it in storage for the last five years. I tried to start the car about every other month, and took it for a long drive (over 100 miles) every summer.
    Well I just took the car out of storage and attempted to get it smogged and registered. It failed miserably. It's burning oil ferociously. At first I thought a stuck oil ring or leaking valve guide. So I replaced the injectors and spark plugs, and poured six ounces of Seafoam in each cylinder. I let it soak overnight, started the car and let it run for 20 minutes. Then I drained and replaced the oil and replaced the oil filter. I purposely only put in 10 liters to make sure the oil tank was not overflowing. Oil is still getting into the intake track somehow. I had the same problem with my Porsche recently, and it was an air oil separator gone bad. I assumed I had the same problem here, but I can't find the air oil separator or even a pcv valve. Is there one? How is oil getting into my intake? Yes I used the search function, and I'm here still perplexed. I was planning on driving this over the next year. Any ideas or advice.
  2. Portofino
    Portofino Formula Junior
    Sep 17, 2011
    863
    Yorkshire UK / Switzerland/ Antibes France
    Portofino
    Added too much oil , overfilled it .
  3. m.stojanovic
    m.stojanovic F1 Rookie
    3,234
    Serbia - Niš
    Miroljub Stojanovic
    If you put 10 litres, you certainly did not overfill the engine (provided you also drained the oil tank).
    The oil separator and PCV:
  4. TorqueJunkie
    TorqueJunkie Rookie
    Monday
    2
    Could be valve guide wear, pretty common on older Ferraris. A leak-down test should confirm.
  5. Portofino
    Sep 17, 2011
    863
    Portofino
    Not so sure . That’s a fuel thingy . If you sniff it it’s fuel not oil in there .
    Spoke to my Indy recently as he had a new model V12 in with the engine out . Long story short they removed 4 L of oil from the induction apparatus. It was flat bedded in , started smoking within 40 miles from a franchised dealer service ( kids / apprentice/ un calibrated oil filler etc etc ) .*
    See it a lot the results of overfilling . Warned me if were to DIY to under fill first then top up .
    Said 348/355s are particularly prone . Remembering there’s the oil tank too to drain . = a lot get overfilled .
    * warranty invalidated bcz it had a aftermarket exhaust fitted . Car was 3 y old .
    Owner speaking to lawyers .
    ps don’t shoot the messenger.
  6. m.stojanovic
    3,234
    Serbia - Niš
    Miroljub Stojanovic
    Yes, I was wrong calling it oil separator.
