Where is the best & least expensive oil change ? | FerrariChat
Discussion in 'New York Tri-State' started by alinaqvi, Jun 24, 2004.
  1. alinaqvi
    alinaqvi Karting
    89
    Somerset, New Jersey
    Ali
    I just put 3,000 miles on my 348 Spyder - what do I need to have done to my vehicle and where should I go ?
  2. robiferretti
    robiferretti F1 Rookie
    Oct 31, 2003
    3,299
    NYC area
    rob ferretti
    i would use mobil 1 synthethic 5w-30 or 10-30, but i am sure some guys swear by the manual and $12/qt oil. But if your looking for cheap change it shouldn't be more then $20 to go to a quick lube or gas station, if you bring your own oil and filter.
  3. DodgeViper01
    DodgeViper01 F1 Veteran
    Oct 1, 2003
    6,867
    That sounds about right.
  4. noahlh
    noahlh Formula 3
    Aug 28, 2003
    2,231
    NYC, NY
    Noah
    Rob -- will the quick lube places groan about a Ferrari? Given Dan's and my experience trying to get a simple tire mounted and balanced ("We're not letting that car in our shop -- too much liability!") I can't imagine the quick lube places are going to want to get involved with an oil change...?
    nlh
  5. DodgeViper01
    Oct 1, 2003
    6,867
    It depends on the shop and most of all the person running it but most places should be fine with it. BUT if the person running the shop has personal preferance then you will be out of luck. Take it to a "nice" place and you will be fine.
  6. pchop
    pchop F1 Rookie
    2,667
    Usually NY often elsewhere.
    I thought the 348 and 355's oil change is not so simple... if you're not familiar with how to remove the filter, you may end up with a mess of oil filled engine compartment.
    Could anyone confirm?
  7. 993 guy
    993 guy F1 Rookie
    May 21, 2004
    3,066
    Bergen County NJ
    Eric D
    I also don't yet own an Fcar, but my 993 is an absolute no no at a quick change oil shop. You have to release the oil from two separate areas in order to drain the pan and the oil cooler. The end result is that you get 10 of the 12 quarts out on a refill...and it's no easy job, especially with two oil filters as well!
    I'd be shocked if a normal "quick change" place would be able to do a proper oil service...IMO of course.
  8. Merdav
    Merdav Formula Junior
    Apr 11, 2004
    980
    Hey Eric, whats going on, long time no hear. Whats with the 355 shopping didnt work out in AZ? What about that one out on the Island?
  9. Black355
    Black355 F1 Veteran
    Feb 3, 2004
    5,255
    10036
    Emil
    As long as there's no oil in the car, changing the filter is easy. Just need the correct wrench. If we had a lift in a garage somewhere, this'd be super simple...
  10. Black355
    Black355 F1 Veteran
    Feb 3, 2004
    5,255
    10036
    Emil
    Oh, and the Ferrari recommended oil REALLY does make the car run cooler. I was skeptical at first, too, but it's true. Werd.
  11. robiferretti
    Oct 31, 2003
    3,299
    NYC area
    rob ferretti
    whats the different ingredient in the other oil vs mobil 1 synthethic?
  12. Black355
    Black355 F1 Veteran
    Feb 3, 2004
    5,255
    10036
    Emil
    Well, in independent taste tests, 4 out of 5 Italian Car Techs agree:
    The 5th guy is an idiot.
    Beats me what the difference is. Maybe it's the soylent green content?
  13. 993 guy
    993 guy F1 Rookie
    May 21, 2004
    3,066
    Bergen County NJ
    Eric D
    It's been a little crazy on my end with work, house hunting here in Ridgewood (wife wants bigger digs and I need a bigger garage!), and my newborn son. I was very close to moving on the AZ car but decided that I feel a little more comfortable buying locally and especially seeing the car before I move on it. Getting to AZ over the past few weeks has been an impossibility. :-(
    I also came upon an old friend who has a 97 355 Spider with 12K miles on it. He ordered a 360 Spider and it is coming in next month. He hasn't decided whether he will sell the 355 and move to the 360 or hold on to the 355 and make a few bucks off the 360. Although the car is red (not my first choice...no offense to those with red F'ers), it may be a wise investment being that I know the car and it has had just a single owner with all records, updates, etc. So there it is...
    How are things on your end? I hope to catch up with you guys one of these days for a run...I keep reading about the club outings and such but I don't think the wife is ready to green light those outings with a full house on my end! ;-)
    Hope to see you soon. How did the Cats turn out?
  14. Black355
    Black355 F1 Veteran
    Feb 3, 2004
    5,255
    10036
    Emil
    Speaking of cats, I have a kitten for adoption if anyone wants. it's a girl, been checked out by Keri's hospital, about 4 months old...
