Where is the FF Engine Number? | FerrariChat
Discussion in 'FF/Lusso' started by GF04RCE, Jan 13, 2014.
  1. GF04RCE
    GF04RCE Rookie
    Dec 2, 2013
    25
    Northamptonshire, UK
    David Martin
    Hi there,
    I really need to locate the engine number on my FF engine. I have looked and looked but cannot locate it. There is a number on the oil pump assembly but as this detachable from the block that cant be it surely....,
    Any help greatly appreciated....
    thanks
    David Martin
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,627
    South East
    Jimmie
    There are usually pictures in the first few pages of the owners manual showing this type of information
  3. 134282
    134282 Four Time F1 World Champ
    40,647
    California
    Carbon McCoy
    #3 134282, Jan 13, 2014
    David, do you need to see the stamping? Because you can find the engine number printed on the first page of your warranty card - it'll be the same page that shows the model type and model year, the original selling dealer, and the original owner.
    You're right that the number on the oil pump assembly is not the engine number. If you look close enough, you'll find a lot of numbers on a lot of different things throughout your engine bay. But your engine number will be stamped into the block. The number will be preceded by the engine type, F151, which will be raised on the block; but the number itself will be stamped. It'll be on a rectangular surface that's been smoothed.
    Below are two pictures of the 599's engine bay. The first picture has a green circle indicating the location of the 599's engine number stamping; the second image demonstrates the appearance of the stamping - that's what you want to find.
  4. GF04RCE
    GF04RCE Rookie
    Dec 2, 2013
    25
    David Martin
    Hi, I need to actually see and photograph the engine number stamp and have looked in all the obvious places.
    But will go back and concentrate on the top of the block....
    David
  5. YAMVS6
    YAMVS6 Karting
    Jan 26, 2011
    138
    ohio
    FF engine number is on bottom of block near flywheel
  6. 134282
    40,647
    California
    Carbon McCoy
    Ouch. Is it visible if the car is on a lift, or does the engine need to be out of the car?
  7. GF04RCE
    GF04RCE Rookie
    Dec 2, 2013
    25
    David Martin
    I have just looked through user manual, and as you say the picture shows the underside of the engine. But i would have thought it would have been on the main block, that bottom section can be replaced... But will go and look....
    David
  8. YAMVS6
    YAMVS6 Karting
    Jan 26, 2011
    138
    ohio
    engine number visible on lift,lower section of block,that would be the main block,lower half,those sections are sold together,matched
  9. YAMVS6
    YAMVS6 Karting
    Jan 26, 2011
    138
    ohio
  10. Raff88
    Raff88 Rookie
    Nov 13, 2013
    23
    Hi Guy,
    Where is located the engine number on the ferrari F12?
    Please help me.
