Where to Buy Dial Indicator That Fits?! | FerrariChat
Discussion in 'Technical Q&A' started by Gumart1, Jun 17, 2020.
  1. Gumart1
    Gumart1 Karting
    Dec 22, 2010
    117
    Highland Park, IL
    Marty
    I'm doing a timing belt change on my 360 Spider and the space is tight in getting a dial indicator in the spark plug hole. Not looking to spend a fortune but accuracy would be nice! Any recommendations would be appreciated.
  2. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,126
    Georgia
    Wade Williams
    I am afraid it would be a custom made unit. A standard dial indicator works but it needs an extension and an adapter to fit in the plug hole. Ferrari had a tool from the factory and Hill Engineering makes the same kit. https://www.ricambiamerica.com/tdc-kit-01-top-dead-center-tool-kit.html $473.72 is a lot but it will show you what you need. I have machined my own plug adapter before, so it is not out of the question to have one made.
    2NA and Gumart1 like this.
  3. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,264
    MA
    Hill Tool is a great unit for a Pro or serious DIYer. I have several Hill Tools.
    Or Use MSC for Deep Reach Dial Indicator. Magnetic Base with Articulating Arm.
    May have to have a steel plate machined to mount base. Not a lot of steel in a 360 engine bay.
    Base plate and Magnetic Holder will also work to time cams if in your plan.
    Gumart1 likes this.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    PM sent
    Gumart1 likes this.
  5. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,387
    The Cold North
    Tom
    I just bought these..they come in 10, 12, 14mm thread sizes. Shopped from Poland.. 70 bucks each..much cheaper then the hill tool..
    QSA, brian.s, Gumart1 and 1 other person like this.
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,214
    Twin Cities
    Tim Keseluk
    Pretty sweet, where did you order them from? I've made a couple myself but that is too cheap not to buy.
  7. tbakowsky
    Sep 18, 2002
    19,387
    The Cold North
    Tom
    Maybe this will help..
    I found them accidentally while looking for other tools..maybe this will help. I'll try to find them again and post a direct link..
  8. 335s
    335s Formula Junior
    Jan 17, 2007
    870
    SF Bay Area
    T. Monma
    FWIW-in my own experience as a prototyping machinist-as well as lifelong Ferrari knucklehead-Polish equipment, while not having the rep that Swiss or Swedish equipment has, is in general terms: excellent, quality, with reproduceable numbers. FWIW-the finest, commercially available cast iron for engine blocks comes out of the Gdansk shipyards in Poland...and don't forget: cold war factotem: the MiG factories were also found in Poland-so there is ALOT of talent/skill there, otherwise Mercedes Benz wouldn't be having had most of the 198 car(300SL) parts made in Poland ..until the scandal involving bogus/fake cars was exposed.....
    Best of all: its really cheap compared to the equivalent Mahr/Etalon etc, equipment.
    FWIW....
  9. tbakowsky
    Sep 18, 2002
    19,387
    The Cold North
    Tom
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,214
    Twin Cities
    Tim Keseluk
    tbakowsky likes this.
  11. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    23,084
    Honolulu
    Kevin
  12. tbakowsky
    Sep 18, 2002
    19,387
    The Cold North
    Tom
    Yes..10mm for the 360.
    Kevin Rev'n likes this.
  13. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,806
    Midwest
    Brian
    I ordered the 10 and 14 sizes, on my home made rig, I used the adaptors from my leakage tester to downsize.
  14. eric355
    eric355 Formula 3
    1,163
    Toulouse (France)
    Eric DECOUX
  15. Kevin Rev'n
    Nov 29, 2009
    23,084
    Honolulu
    Kevin
    I picked up the Hill Engineering set and the quality is beyond measure. I sort of justified the purchase since I use Mitutoyo Dial Indicators all the time when I'm machining or measuring but I didnt have a metric one! ;-) I will use the indicator outside of TDC functions so it made sense for me. If anyone is piecing together stuff the indicator is model No. 2330S 10 but it has a custom engraved backplate that says Hill Eng. Do your own DD if you go this way I am not sure what they might have had customized. It's a 30mm travel indicator with a removable tip that you screw the 165mm extension onto.
  16. mwr4440
    55,933
    Bavaria, The 'Other' Germany
    Mark W.R.
    Probably same guy I got mine from with High-Accuracy German Gauges.
  17. ccalo
    ccalo Karting
    Aug 20, 2013
    99
    CT us
    Carmine Calo
    Can you confirm if the 10mm tool still works with the valve cover not removed? Looks super close by the picture, but I’m taking on the cam change and I would like to know if I need to also purchase the gasket set. Thx
  18. Supernaut
    Supernaut Karting
    Dec 3, 2019
    147
    Annapolis MD
    John Panek
  19. tbakowsky
    Sep 18, 2002
    19,387
    The Cold North
    Tom
    Yes it will work with the valve cover in place.
  20. ccalo
    ccalo Karting
    Aug 20, 2013
    99
    CT us
    Carmine Calo
    Thank you
  21. ccalo
    ccalo Karting
    Aug 20, 2013
    99
    CT us
    Carmine Calo
    I just completed my timing belts on my 360 and the 10mm worked perfectly! Thank you!
  22. RedNeck
    RedNeck F1 World Champ
    10,016
    The CSA
    Me
    I also sprang for the HE version. It's extremely well made and quite honestly, could have been more expensive considering it's application... even at $400.
