Where to connect battery tender? | FerrariChat
Discussion in '612/599' started by Inadeje, Aug 3, 2020.
  1. Inadeje
    Inadeje Karting
    I have the original tender for the 599 which has the socket end (no cigarette lighter), where do I connect this? Is it behind the little door in the right of the trunk? If not where is the correct connector located on the car?
    thanks in advance
  2. Zbaroom
    Zbaroom Karting
    May 27, 2012
    106
    Dubai
    Zaini
    #2 Zbaroom, Aug 3, 2020
    It is behind that little door just above the battery cutoff switch in my car but could be below as indicated in the manual ...
  3. Skidkid
    Skidkid F1 Veteran
    9,571
    Campbell, CA
    John Zornes
    Yes, behind the little door on the passenger side of the trunk.
  4. Inadeje
    Inadeje Karting
    Thanks! Much appreciated
