Where to find Cavis fuel hose | FerrariChat
Discussion in '206/246' started by simonc, Oct 2, 2016.
  1. simonc
    simonc Formula Junior
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    #1 simonc, Oct 2, 2016
    I am looking for a source for the clear/green Cavis fuel hose that goes between the carbs on my 246GT E-series. I currently have braided cloth covered rubber hose and recently lost 1/2 a point at a concours because of this.
    A quick search on the web shows photos of carbs with 'Cavis 7x12' written on the hose in this position but my connectors are 8mm (and they are original as far as I know). These two pipes are each only 70mm long - see the photo below.
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,639
    Toronto / SoCal
    Rob C.
    Superformance stocks and sells all the hose you need. It will not have the white 'Cavis' marking on it as the new stuff has a digital print on it that can be wiped off with a rag. I see no reason why you should get a deduction to be missing the Cavis writing because originally that writing appeared every so many inches so theoretically it was very possible to cut the two pieces you need without ever getting any print on the hose.
  3. simonc
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    Superformance don't have 8mm, only 7mm - that is the problem. The deduction was because my hose is braided cloth and not clear.
  4. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    I used their 7mm. It went on fine after heating it a bit with a heat gun.
  5. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,639
    Toronto / SoCal
    Rob C.
    Understood the deduction for the braided cloth hose is correct however my point is that I would not get hung up on having the Cavis writing on the hose. I too used 7mm with no problems.
  6. 19633500GT
    19633500GT F1 World Champ
    13,087
    Blueberry
    Muffin-Tops
    #6 19633500GT, Oct 2, 2016
  7. simonc
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    Yes that looks like the sort of hose. Preferably it would have a green tint (it is hard to see if yours is tinted or clear) and would have Cavis printed on it (but that is not so critical).
    Do you have a source?
  8. 19633500GT
    13,087
    Blueberry
    Muffin-Tops
    #8 19633500GT, Oct 2, 2016
    I have this.
    But you'll have to wait until I go to my storage tomorrow to confirm if it has the print on it etc.
    I have about 200 items for vintage 330/365/246 etc. so it's likely correct.
    Ken
  9. simonc
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    That looks like the sort of hose, assuming it is fuel hose and 8mm inside diameter. It should have a green tint (it is hard to see if your is clear or tinted green from the photo) and have 'Cavis' printed at intervals along teh length (but that si not so critical.
  10. simonc
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    Ken, if you have some available I would be very interested. Thank you
  11. 19633500GT
    13,087
    Blueberry
    Muffin-Tops
    I'll look in the morning to see if it's exactly what you need.
  12. mar3kl
    mar3kl Formula Junior
    Nov 17, 2011
    470
    Silicon Valley
    Mark
    Newco.com has 7x12 and 8x14 in correct color with cavis markings.
  13. 19633500GT
    13,087
    Blueberry
    Muffin-Tops
    #13 19633500GT, Oct 3, 2016
  14. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,332
    Iain
  15. simonc
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    Sorry Ken but I need 8mm ID
  16. simonc
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    Thanks, I'll try that first
  17. simonc
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
  18. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Simon, if you need a short piece let me know, I have some left over from previous work
    Tony
  19. simonc
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    Tony - pm sent & thank you
