Where to get new Expansion valve and Dryer for 348? | FerrariChat
Discussion in '348/355' started by ferrari360driver, Apr 10, 2019.
  1. ferrari360driver
    Apr 8, 2012
    203
    Florida
    Rich
    Hey guys, I am having various problems with my ac. Wanting to know if I can still get those parts new? My ac blows cool not ice cold. High pressure side at idle to 2K rpms is 300-350 PSI. Low side 35 at idle and 30 psi at about 2K rpms. Compressor has very few miles on it since last replacement. Unsure of expansion vale or dryer.
  2. Koenig1
    Koenig1 Formula Junior
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    as far as the dryer goes, https://www.polarbearinc.com/ has them for under $50. Call them as there are 2 types/fittings. The lady I spoke with asked for a pic of the old, for fitting purposes, and shipped out quickly... Based out of FL. Website didn't show the dryer last year. maybe they have updated since, although they do list the 355....
  3. plugzit
    plugzit F1 Veteran
    7,785
    Redondo Beach, CA
    Bruce Bogart
    I have a new expansion valve for you. PM me.
  4. chopsui
    chopsui Karting
    Feb 27, 2019
    119
    Austin, Tx
    Sorry to bring this thread back from the dead, but I have the exact same issue as the OP - same pressures at idle, not super cold, etc. Is there a generic expansion valve available? (I have already replaced the dryer with the polarbear unit)
    Also, do people typically replace that insulation stuff that covers the original valve with something or just leave it bare?
  5. Qavion
    Qavion F1 World Champ
    14,438
    Ian Riddell
    If it's in the same location as my old Lotus Esprit, because the pipes are so cold, condensation builds up on the outside and drips onto the feet of the passengers or onto the carpet. I found some insulation for my Lotus, not sure if Ferrari stockists have it.
  6. JLF
    JLF Formula 3
    Sep 8, 2009
    1,708
    I redid my Porsche ac, you can buy Prestite tape at autozone to cover the expansion valve. It’s like a sticky, malleable cork tape. I don’t know what they use on Ferrari’s but I assume it’s universal. You should cover it.
    https://www.autozone.com/sealants-glues-adhesives-and-tape/tape/santech-prestite-tape/158980_0_0
    Qavion and chopsui like this.
  7. ferrari360driver
    Apr 8, 2012
    203
    Florida
    Rich
    put my new valve in, new drier, vacuumed the system for 45 mins charged with 950-1000 grams and still only blows 70F from the vents. At hot idle the pressures are 49 PSI low side 245 PSI high side. 2500 RPM idle they are 38 PSI low side 290 PSI high side. Compressor may be weak
  8. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,628
    San Carlos, CA
    Mitchell Le
    If you are getting a delta of 190 psi between low side and high side, the compressor cannot be weak.
  9. Carmellini
    Carmellini Formula 3
    Jul 16, 2019
    1,009
    I would agree; an improperly calibrated TEV could create this situation. AMHIK
