Where to get second gears | Page 2 | FerrariChat
Discussion in 'Boxers/TR/M' started by spaceship, Jul 13, 2017.
  1. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,934
    romano schwabel
    to make those gears is no problem. the problem is to get the rings for the synchro. sure, you can remove those from the old gears, but mostly they get damaged a little but you still can laser weld those to the new gears
  2. ago car nut
    ago car nut F1 Veteran
    5,267
    Madison Ohio
    David A.
    I removed the sychro ring from my damaged 1st gear. Drilled from the back with carbide drill 2 holes, and gently push the ring off with punch. The gear has a spline that the ring presses on. So the sychro rings can be salvaged.
  3. Stefan Elshout
    Stefan Elshout Karting
    Dec 1, 2011
    166
    Holland
    @Melvok: If you google: 'tandwielen nederland' there are already six companies that produce sprockets and gears, and non of them can be more than 2 hours driving distance from central part of Holland;-)
    But I'm currently having some sprockets made at a company in Gorinchem but some other companies might be able to make them (as well).
    Just walk in there with your broken gear and discuss the problem and possibilities.
  4. TR91
    TR91 Karting
    Mar 8, 2008
    84
    Scottsdale, AZ
    Yessir.
  5. turbo-joe
    Apr 6, 2008
    8,934
    romano schwabel
    great :)
    so start puting all together now and enjoy the car again
  6. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,117
    Mel
    Can you give an indication of the price Verbaan charges for a gear set Stefan (for instance the first or second gear of a TR gb) ?
  7. Melvok
    Jul 25, 2008
    14,117
    Mel
  8. Stefan Elshout
    Dec 1, 2011
    166
    Holland
    I will pick up some gears next month and than i will ask them if it would be possible to make these gears and what it would cost. Could you post a picture of the spline inside as well?
  9. Melvok
    Jul 25, 2008
    14,117
    Mel
    Yes, when I am in my F garage next weekend ...
    You may borrow this wheel if needed ...
