Where to plug in my timing light? | FerrariChat
Discussion in '308/328' started by flyngti, Jul 10, 2010.
  1. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,249
    Snohomish, WA
    Eric L
    Ok, sounds like a silly question. Engine's in the back, battery's in the front. When setting the timing, where do you get power for your light? Do you have looooong power cables for your light? Plug in somewhere else?
    I had a similar problem with a BMW 2002 when I relocated the battery to the back. The first time I used my timing light, I had no place to get power. I ended up putting in a power distribution block at the front of the car to clip my light into.
  2. tommott77
    tommott77 Formula Junior
    Feb 1, 2009
    652
    NC
    Tom
    #2 tommott77, Jul 10, 2010
    I just use an auxiliary battery.
  3. afterburner
    afterburner F1 Rookie
    3,484
    Switzerland
    Urs STEMMLER
    The Mondial has a 12V socket in the engine bay, where you can plug in the emergency light and other equipment.
  4. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,328
    On the 328 there is a power connector on the right side of the engine cover that powers the number plate lights - I use that & switch the side lights on (!)
  5. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    A jumper cable and a piece of 1" X 2" wood (to keep the clamps apart).
  6. zeiglerr
    zeiglerr Karting
    Oct 23, 2009
    69
    Lansdale, PA
    Reid Z.
    I also use a piece of 1X2 wood to keep jumper cables apart, but one of these days I'll make an adapter for the 12V aux. lamp socket in the engine bay.
  7. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    +1
  8. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I use the +12v line on one of the coils.
  9. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,249
    Snohomish, WA
    Eric L
    Thanks for all the suggestions.
  10. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    I did the same as tommott77 -- you just plonk an auxiliary 12V battery down on the ground at the rear end of the car.
