Where's a good place to buy body panels? | FerrariChat
Discussion in '348/355' started by squid, Apr 2, 2023.
  1. squid
    squid Karting
    Oct 5, 2006
    153
    My mirror and mirror post are rusty, I talked to a body shop about it and they suggested just replacing the part rather than trying to recondition it. Where can I get stuff like this?
    Thank you
  2. phrogs
    phrogs F1 Veteran
    7,322
    Michigan
    Can you post a photo of this rust.
  3. ChoonHound
    ChoonHound Formula 3
    2,122
    Saint Michaels, MD
    Lucas
    Get the part number from one of the may online sellers. Google it.
  4. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    924
    Europa
    Bob
    last time I looked for one "new" door mirrors from parts dealers were unobtanium & second hand ones were in the thousands. If you buy a second hand one you'll need to have it repainted so you may as well just get yours repaired. It'll be quicker and far cheaper. Oh, and whatever you do, don't break the mirror glass...
    308 GTB, squid and ChoonHound like this.
  5. jqpd99
    jqpd99 Formula 3
    Jul 25, 2007
    2,449
    Ottawa
    DFO
  6. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,610
    Toronto / SoCal
    Rob C.
    I would absolutely get that part repaired. A replacement as already said would be big money and need painting anyways. It is totally possible to neutralize that rust and fix it to perfection without a huge amount of work.
    308 GTB and spaghetti_jet like this.
  7. Ricambi America
    Sponsor Owner
    No way would buying a new one be less expensive than fixing what you have. Anything you buy -- and let's assume you find a brand new/original mirror -- will need plenty of prep & paint to match the door. Buying something used suddenly entails your perception of acceptable quality vs. the seller's perception.... and more prep & paint.
    ChoonHound and spaghetti_jet like this.
  8. squid
    squid Karting
    Oct 5, 2006
    153
    I'm fine with a used part. I just haven't seen any mirror pods at the few breakers I've found. Looking for alternatives
    ChoonHound likes this.
  9. squid
    squid Karting
    Oct 5, 2006
    153
  10. jqpd99
    jqpd99 Formula 3
    Jul 25, 2007
    2,449
    Ottawa
    DFO
    squid likes this.
  11. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,529
    Jeff
    If I remember correctly the stem of the wing mirror is aluminium so that's not rust. Id remove it anyway but if you use something like a wire brush on a drill you should be able to remove the paint and be left with a clean finish.
    308 GTB likes this.
  12. phrogs
    phrogs F1 Veteran
    7,322
    Michigan
    i don't see how a body shop cant repair that.
    The mirror comes apart easily or should be easy for a body shop.
    unlike a basic car where millions are made these are a bit harder to find, the cost isn't going to be cheap and the new part still needs to be painted.
    308 GTB likes this.
  13. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,663
    Looking at the picture it seems like the added work on the rusted part compared to a new part will be less than 1 hour of labor.
    So, the only way a NOS part would be cheaper is if you are playing the body-person $1,000 per hour.
    The going rate around here is $25-$100 depending.
  14. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    The important thing about aluminum corrosion is it must be properly chemically treated once stripped. If you scraped off the blistering paint it would likely reveal a white powder and severe pitting of the surface. Once treated, metal prepped, primed & filled, and painted.....good as new ! This type of corrosion is common in aircraft structures especially in float planes.
