Where's the brake light switch on a '84 Mondial? | FerrariChat
Discussion in 'Technical Q&A' started by surfdoc37, Jan 29, 2007.
  1. surfdoc37
    surfdoc37 Karting
    Nov 19, 2004
    124
    St. Louis, MO
    Mark M.
    Brake lights went out simultaneously, I am assuming/hoping it is a bad switch, got a new one, but this novice mechanic sure doesn't know where it goes. Any help appreciated.
  2. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    Follow the brake pedal up under the steering column, 99% of them are fitted there ;) Make sure you adjust it to work correctly when you replace it should it be faulty
    Silly question but have you checked for a blown fuse?
  3. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    Before replacing the switch, check the fuse and fuse block. The Mondial fuse block is notorious for causing electrical problems. Check the switch to make sure it's not just stuck/dirty. And check the bulbs. There is always a chance, though slim, that they both blew. IIRC, that switch is interchangeable with some other cars of the same vintage (not a super-high-tech Ferrari part, it was a stock item they bought). Take it to a NAPA and check the catalogues for foreign parts. You might find a cheap direct replacement.
  4. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,424
    Dumpster Fire #31
    SMG
    accutually you only need adjust the nut on the switch in the pedal box. from the bonnet side if you look next to the booster you'll see the pedal box, the back end of the switch and it's electrical leeds should be visable. loosen the jam nut and rotate the shaft until the brake lights work right again.
    i just went thru this a few weeks ago on my modi.
  5. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,424
    Dumpster Fire #31
    SMG
    the brake lights per DOT should not be fused and should come on with the car off, now if you have a Euro car then they won't work until the key is on
  6. FasterIsBetter
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    My Mondial was a Euro car. Everything ran through that rat's nest of a fuse block. That was part of the problem with everything electrical on that car.
  7. surfdoc37
    surfdoc37 Karting
    Nov 19, 2004
    124
    St. Louis, MO
    Mark M.
    Thanks for the info (I did manage to check the fuse box); as soon at the temperature here goes above 18 degrees I'll push it out in the driveway to take a look.
  8. mg54
    mg54 Rookie
    Jan 12, 2005
    48
    Massachusetts
    Michael Gardner
    The switch is easily accessed by opening the front hood and looking to the lower inside of the brake booster. It has a few wires plugged into it and simply unscrews
    mike g
