Which connecting rods? | FerrariChat
Discussion in 'Technical Q&A' started by mk e, Mar 14, 2008.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,783
    The twilight zone
    I have to admit that I’m getting myself a little confused at the moment over connecting rods and money.
    For those the don’t know, I’m assembling a 400 V12 with the stock 78mm stroke and a 86.5mm bore making 5.5 liter. Most project drift a bit and mine more than most so the engine that started off to be 550hp at 7500 rpm is heading toward 650hp at 8500 rpm….or maybe a little more :)
    So, although the original plan called for stock connecting rod with better rod bolts I’m now questioning the decision. I can still kind of talk myself into the stock rods since it’s not a race or “track” car and will never be a race or “track” car so it will honestly see redline pretty rarely and for pretty short durations.
    I know the best thing to do is drop $5-6k on new Ti rods but that is a LOT of money in my world. I could buy the raw Ti and make the rods, I guess that would cut the price about in ½ but would be a ton of work.
    The next best think would be new good quality steel rods but I honestly don’t know how much better they would be than the stock steel rods which are good quality. I know I did run an engine with a longer stroke (82.5mm) in roadraces for 2 seasons at 9000 rpm with no issues. If that wasn’t bad enough the rods had a billet small end welded on to the forging to get the length I wanted (the custom carrilo showed up too late to make it into the engine and are still on my shelf brand new over 10 years later :( ).
    So after the long lead in, what are others doing? Who’s tried what in which engine?
  2. JCR
    JCR F1 World Champ
    11,006
    H-Town, Tejas
  3. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,424
    Dumpster Fire #31
    SMG
    mark, what the dims of the rods you'll need. I can search thru the wsm's and see if any stock ferrari ones will work.
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,783
    The twilight zone
    I'll measure them up tonight.
    The stock 400 rods will work no problem, but I'm concerned about whether they are strong enough to live to 8500 rpm???
    I talked to the shop guys and they're game for making a set of Ti rods for me if I decide to try that. They could be wire edm'd out of plate Ti with very little scrap so I sent out a couple RFQs checking on material.
  5. james patterson
    james patterson Formula Junior
    Dec 8, 2003
    417
    Dallas Texas
    James Patterson
    We've run the stock rods to 9k on boost with no issues - road not track. They are strong rods but heavy, I don't recall ever seeing one fail that was not caused by a different problem. Carrillo and Crower both make good rods but in the past they have always been very slow on delivery for custom bits for us. We have had good luck with Pauter rods and RoDy cranks for quality, price, and delivery time. The steel Pauter rods weigh in the low 400 gram range for a TR length rod if I remember right. The Crowder Ti rods we have run weigh in the low 300's as I recall.
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,783
    The twilight zone
    It measures the same as a 308 rod, so I guess 355 or 360 rods would do then?
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,783
    The twilight zone
    Thanks!
    I was thinking the rods SHOULD work....but hearing that they DID work puts my mind a little more at easy.
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,783
    The twilight zone
    Anybody know how the ferrari Ti rods (355/360) hold up?
    Are they bullet proof or do the racers still change them out and if so what do they replace them with?
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,783
    The twilight zone
    Does anybody know about the life expectancy for Ti rods?
    Do the threads hold up to re-torquing multiple times?
    Any corrosion concerns, I’ve heard the main bearing journals can suffer galvanic corrosion from the bearings)?
