Which Fuse Controls the Dome Light in 348? | FerrariChat
Discussion in '348/355' started by 76Steel, Dec 20, 2014.
  1. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,482
    New Jersey
    Do you guys know which fuse controls the dome/cabin light and
    the door red warning light on a 94 Spider? I think it is the same fuse.
    Is it in the footwell fuse box as well? Location of the fuse?
    Thanks very much for any help.
  2. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,482
    New Jersey
    Ok. I found it. It is fuse 3, top row from the right.
    Thanks.
  3. albert328gts
    albert328gts Formula 3
    1,667
    California
    Is that in the Footwell?
  4. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,482
    New Jersey
    Yes, in the footwell.
  5. albert328gts
    1,667
    California
    Project for tomorrow!
  6. 76Steel
    76Steel Formula 3
    Sep 8, 2007
    1,482
    New Jersey
    No problem! As I found out the dome light has several settings which are made active
    by clicking the light housing in/leaving it flat/and up if that makes any sence. I thought my
    light did not work, but then it was a matter of clicking it into the right position.
    I also found that the bulb that lights up the red round light in the passenger's side door works
    on the same fuse. If you have red side door light working you might just need a
    new bulb in the dome light?
    Anyways, just sharing what I learned. Hope your 348 is doing great!
  7. albert328gts
    1,667
    California
    It's amazing how easy anything is to fix when you know what to look for
    Opened that up and 5 minutes later I was good to go.
    Thanks again, car is doing great - tomorrow am off for a nice long drive.
