Which Hose and HOW BIG a PITA ... | FerrariChat
Discussion in '308/328' started by mwr4440, Nov 16, 2019.
  1. mwr4440
    58,052
    Bavaria, The 'Other' Germany
    Mark W.R.
    The title says it all.
    Ruin my day ..... :(
    The hose 'disappears' behind the driver's (left) side fuel tank.
    What kind of $ and a job am I looking at here?
  2. Rifledriver
    37,288
    Looks like an original hose. A big PIA but needs to be done. In many cases we splice a piece in but that is an old hose and needs replacement.
    Get a squirt bottle full of water/dishsoap mix. With safety wire or similar stitch the end of the new hose to the end of the old hose. get access to the front end, squirt soap everywhere at both ends and get a friend to feed the new hose while you pull on the old.
    A hose that old will have rusted to the panels in the rocker box where it runs. It isn't a lot of fun.
  3. mwr4440
    58,052
    Mark W.R.
    Thanx Brian.
    Isn't there 2 hoses one TO the radiator and one FROM the radiator?
    If so, shouldn't I do both?
    'While I'm there,' of course?
  4. Rifledriver
    37,288
    One goes from the large coolant pipe near the back of the radiator to "t" and goes to both heater cores. The other is the hose you are dealing with and it also goes to a "T" and then to both heater valves then on to the cores.
    Yes, I'd take the trunk liner out and do them all. It's time.
  5. mwr4440
    58,052
    Mark W.R.
    #5 mwr4440, Nov 16, 2019
    Ok. Darn ... :(
    The front plastic trunk liner is already out. :)
    Which way should I PULL these suckers;
    FROM the FRONT or FROM the AFT of the car?
    IF it is rusted to the car, Push, Pull and Twist to 'Break' it Free .... Correct?
  6. Rifledriver
    37,288
    It will be much easier to pull it from the front. Lots of soapy water. Over the front of the tank, up in the rocker panel....everywhere.
  7. mwr4440
    58,052
    Mark W.R.
    Thanx Again !!!
    Oh, should the gas tank come OUT First?
  8. Rifledriver
    37,288
    It would not be unusual to see a great deal of corrosion on the nipple in the head. I have had to replace a few. I just drill it out, tap the hole with a pipe thread tap and install a barbed brass nipple from Home Depot. GM crate motors intended for marine use do that at the factory.
  9. Vonbarron
    Vonbarron Formula 3
    2,279
    Westside Mofo
    S B
    I did both mine with tank in, was pretty easy and by all means splice in new hose to old
  10. ulf308qv
    ulf308qv Karting
    Nov 1, 2003
    100
    Sweden
    Ulf M
    Tank in, pull it from the front. Did mine some years back, went pretty smooth.
  11. mwr4440
    58,052
    Mark W.R.
    Thanx ALL!!!
  12. paul01
    paul01 Karting
    Jul 31, 2011
    104
  13. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Do both hoses while you are at it (coolant and vacuum hose.) You need two people, one pushing through from the back and one pulling from the front (gently and after the push)
  14. Rifledriver
    37,288
    I am quite certain he has a hose problem but it is nearly as certain he has some level of nipple problem as well.
  15. mwr4440
    58,052
    Mark W.R.
    What's good to help eat this type of corrosion away so I can get the nipple out and not damage the surrounding aluminum?
    Suggestions?
  16. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Ammonia or diluted acid but make sure you stop it going elsewhere and rinse well. You will probably need to use a chisel and hammer carefully as they used a hard sealant.
  17. mwr4440
    58,052
    Mark W.R.
    Guys,
    I must be misreading something.
    In the '81 GTSi Parts CAT I was looking at those hoses are SHORT.
    They mate to metal pipes which run most of the length of the car. One would NOT have to Pull the hose near anywhere to replace them from the pics.
    What am I missing?
  18. paul01
    paul01 Karting
    Jul 31, 2011
    104
  19. paul01
    paul01 Karting
    Jul 31, 2011
    104
    These are the radiator connections with the bigger diameter (40mm).
    "metal pipes which run most of the length of the car" -> yes
    The other thing is a smaller hose to the rear cylinder head (pictures above).
    Paul
  20. Rifledriver
    37,288
    Drill, pipe tap, new nipple locally available. Everything you need at Home Depot. In the Fatherland there should be a similar resource.
    rjlloyd likes this.
  21. Rifledriver
    37,288
    The aluminum pipes going down the center of the car are for the radiator hoses. In the July 80 parts book table 20 or the November 81 parts book table 19, part # 39 is the heater hose rubber all the way through the left rocker box.
    miketuason likes this.
