Which "+" post in engine bay? | FerrariChat
Discussion in '348/355' started by ketel, Mar 24, 2019.
  1. ketel
    ketel Formula 3
    Aug 6, 2007
    1,355
    Sausalito, CA
    Gents - Rookie question I know, but battery went flat in the 355 Spider (even with cut off knob in off position) so I am having to charge the battery back to life. I'd normally just pull the battery out of the engine wheel well and charge it directly but the vehicle is stored in garage spot with no power available and it's against a wall so hard to access the right side.
    Manual says to charge using the remote posts in the engine bay and manual says "hook up to the appropriate post" but no indication which of the the three it is. So, which of the 3 posts should I hook up the "+" terminal from the charger to? - the left, middle or right post? Thanks all.
    ketel
  2. RCKSTR
    RCKSTR Karting
    All 3 are connected to each other, but the forward most cable goes to battery
    Qavion likes this.
  3. Rifledriver
    37,232
  4. WATSON
    23,802
    WI
    Who cares = Doesn't matter
  5. Qavion
    Qavion F1 World Champ
    14,423
    Ian Riddell
    Don't forget to put the battery disconnect switch to its normal position (ON) for charging, otherwise you won't have a return earth path.
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Plus 355 on what Ian said.
  7. m.stojanovic
    m.stojanovic F1 Rookie
    3,288
    Serbia - Niš
    Miroljub Stojanovic
    Looks like your battery has a high rate of self-discharge, i.e. unable to take and hold the charge, meaning that you will have to replace it. After you have recharged it, check it a few days later to see if it is still holding that charge. Batteries should not be allowed to go below some 11.5 volts, for any prolonged period of time (2-3 days at 11.5 V should be ok), as the almost irreversible sulfation process in the battery will "eat-up" its capacity.
    If you find that the battery still loses charge rather quickly, if the battery is still fairly new, you may try to somewhat reverse its sulfation with one of the special chargers/desulfators like PulseTech Xtreme or BatteryMINDer but there is no guarantee of full battery recovery.
