Which Sanden compressor? | Page 2 | FerrariChat
Discussion in '308/328' started by mike996, Mar 31, 2021.
  1. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,153
    SanFrancisco BayArea
    1983 US 308 GTS QV
    A curiosity question since I still use a York compressor:
    Are Sanden compressor clutches available with pulleys that have our 11M (11mm wide) belt profile?
    (There are no York clutches that have 11M profile pulleys.)
  2. MFlanagan
    MFlanagan Karting
    Dec 21, 2016
    160
    I found those bolts difficult to deal with, too. I exchanged the ones supplied to Carriage Bolts that made the second wrench, not so necessary.
    Mike Flanagan
  3. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,912
    Mike 996
    I tried to call GT Car Parts using the number on their website and three attempts (to be sure I dialed correctly) resulted in reaching the Phoenix Church of Christ. They did not have any air conditioner parts! :)
    Milkshaker0007 likes this.
  4. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    I just called the number and was answered by GT Car Parts. Maybe this was a sign from a greater power?
  5. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Since I was running new hoses I ran them the other way around the fuel tank and up to the compressor. My thought is that I can undo the bolts and set the whole thing outside the car on the floor for my next service or engine removal and not disconnect the lines. Fender liner fits fine, no issues so far.
    Aus_yz and steven_ew like this.
  6. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,912
    Mike 996
    Yeah, I guess the greater power wanted me to order from Polar Bear...so I did! ;)
  7. mauriciocaste
    mauriciocaste Rookie
    Jul 4, 2014
    24
    I ran mine under the tank, and like Brian said, you undo the bolts and the whole unit sits on the floor without having to disconnect the lines. I guess great minds think alike
    2cam likes this.
  8. MFlanagan
    MFlanagan Karting
    Dec 21, 2016
    160
    I wish I had thought of that!
    Mike Flanagan
  9. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,912
    Mike 996
    I like the under-fuel tank hose routing! :)
    A casual observation re the Sanden which, I assume (hope) has never been an issue...
    The upper mount for the York, which is also used for the Sanden, attaches directly to the belt cover. It does not use a 'through-bolt' or stud to the engine block. The lower mount for the York does use two studs that mount to the engine block but that mount is not used for the Sanden.
    So the weight of the Sanden compressor plus the load/tension of the belt is totally on the aluminum cam belt cover. This seems like it would be a problem over time - either cracking the cover or loosening/stripping the studs out of the cover.
    I guess it's not a problem though...Sandens have been running this way since the (euro) cars were built and on all York conversions for years... right? ;)
  10. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    Du_Man, Brian Harper and 2cam like this.
  11. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    That GT Car Parts set up looks great. I wish I'd known about that six months ago!
  12. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,912
    Mike 996
    Yeah - looks nice. I think I'll fabricate some sort of support for the Sanden mount I'm getting to use at least one of the studs into the engine block.
  13. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,912
    Mike 996
    Brian, do you have any idea, offhand, of how many feet of refrigerant hose total you bought to make that setup?
  14. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,674
    San Carlos, CA
    Mitchell Le
    You also need an expensive line crimper ...
  15. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,912
    Mike 996
    #40 mike996, Apr 19, 2021
    Yes, I'm buying one...
    Actually, the way it looks right now, I'm not going to get to replumbing the AC system or installing the EZ-steer power steering right now. We are leaving for the UK in about 4 weeks and I'd rather get the car up and running for a while before we leave. We won't return until December so the AC/PS will probably be a 2022 project.
    So I'm just going to fit the AC compressor and the belt leave the current hoses disconnected/taped. If I can't easily find the proper belt, I'll just mount the compressor in position and sort all the AC stuff out later.
