News
Which side of the clutch goes toward Pressure Plate on 308?
Discussion in 'Technical Q&A' started by 308GTS, Oct 6, 2004.
  1. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,220
    TN
    I am in the process of replacing my clutch on my 308 QV and I am pretty sure the raised section/side of the clutch disc hub goes toward the pressure plate/bell housing side. The other side of the clutch disc hub is flat. I just wanted to make sure I have it right. Currently, I have the rasied side facing the pp and bell housing.
  3. Rifledriver
    Rifledriver Two Time F1 World Champ
    27,086
    Austin TX
    You got it right.
    FYI Ferrari clutches go in different ways on different models. If in doubt place the disc against the flywheel, if the hub hits the flywheel center, it's wrong, if the friction surface hits the flywheel, it's right.
  4. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,220
    TN
    Thanks. I appreciate it. I just wanted to make sure.
