Whine from Air Pump on Mondi 8 | FerrariChat
Discussion in '308/328' started by DougS026, Jul 6, 2006.
  1. DougS026
    DougS026 Formula Junior
    Oct 4, 2005
    325
    Long Island, NY
    Doug S
    I have a whine (almost sounds like a supercharger) while accelerating on my Mondi 8. I’ve been told that this is from the air pump and is normal. Two questions:
    1) Do the rest of the Mondi 8 guys have the same issue?
    2) If I want to disconnect the air pump, can I just take the drive belt off or is there something else that I need to do like plug the hoses, etc.
    Thanks,
    Doug
  2. sjmst
    sjmst F1 Veteran
    Jul 31, 2003
    9,854
    Long Island, NY
    Sam
    Yep, I had it too.
    Not sure. I think just taking the belt off is all.
  3. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    As long as the check valves are not rusted out, you can remove the belt. Not uncommon for these GM style air pumps to make racket.
  4. Mondialmike
    Mondialmike Karting
    Mar 12, 2005
    217
    London
    Mike Hunnisett
    Curious. I've just noticed a whine similar to yours following the replacement of my alternator, also on a Mondial 8. I wandered if I'd over tightened the belt or if the water pump is on its way out.
