Whining noise from engine ferrari 308 | FerrariChat
Discussion in '308/328' started by doggydoggen, Nov 24, 2023.
  1. doggydoggen
    doggydoggen Karting
    Apr 25, 2023
    120
    Sweden Umea
    Doger Karlstrom
    what do you think about this whining noise, i dont think it is the transmission gears, more like a bearing, idler wheel?,timing belt tensioner bearing?
  2. Glassman
    Glassman F1 World Champ Rossa Subscribed
    Apr 23, 2002
    15,238
    Montana, Oregon, Hawaii
    Sounds to me like a belt and or bearing. I would get a stethoscope and listen around on the passenger side to locate the source.
    If timing belts and bearings had been replaced in the last 7 years I would doubt a cam belt bearing.
  3. Rifledriver
    37,122
    Stethescope. I wouldn't be driving it around until it is figured out.
    Whoever installed the spark plug wires put the distributor boots on upside down.
  4. Rifledriver
    37,122
    We have seen brand new tensioner bearings make noise. Age simply is not a factor.
  5. Glassman
    Apr 23, 2002
    15,238
    You have most likely seen way more than I have!!!!!!
  6. Dockboy
    Dockboy Formula Junior Silver Subscribed
    May 11, 2013
    610
    Maryland
    Did you buy that car?
    That video is from a car that was on BaT a while ago.
  7. doggydoggen
    doggydoggen Karting
    Apr 25, 2023
    120
    Sweden Umea
    Doger Karlstrom
    no , i think it still is for sale?
  8. doggydoggen
    doggydoggen Karting
    Apr 25, 2023
    120
    Sweden Umea
    Doger Karlstrom
    then it must be bad quality bearings, a new bearing should be quiet.
  9. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,608
    California SF bay area
    Paul
    The only failure I've had is the little double A/C belt tensioner bearing. They are real small bearings stacked side by side with a spacer between them and I recall a very similar chirp-like squeak before they went..
  10. Basal Skull
    Basal Skull Formula Junior
    Oct 26, 2010
    427
    Vancouver BC
    Odd they think they can sell a car sounding like that
  11. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,851
    "There's no warning lights on" -- well, of course, as there are virtually no warning lights ;)
    It's been stripped of every last piece of emission equipment, and I'd bet the slow down lights don't work...
    waymar and Rifledriver like this.
  12. LB427SC
    LB427SC Karting
    Aug 5, 2021
    132
    Wales, UK
    Lloyd Barnes
    Bearings on the belt drive pulleys?
    Mike Florio and Sergio Tavares like this.
  13. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    Waterpump belt has not shimmed correctly
    Good to catch this now
    Take the small key pen laser and set it in the groove of the pulley then rotate to see aligned with next pulley
  14. Rifledriver
    37,122
    Shimmed ?
    Sergio Tavares likes this.
  15. Sergio Tavares
    Nov 15, 2018
    1,308
    Sergio Tavares
    To me, it sounds like the belt is riding on the side
  16. Rifledriver
    37,122
    And just how is shimming going to fix that? There is no shimming. There is no place to shim it. WTF do you mean shimmed correctly?
  17. Rifledriver
    37,122
    By the way. Just to be clear. Anyone guessing at this noise is just guessing and it isn't productive.
    Glassman with the stethoscope idea was really the only one showing a path forward.
    Automotive stethoscopes are really cheap.
    Glassman likes this.
  18. Glassman
    Apr 23, 2002
    15,238
    Should be able to be easily verified....................with a Stethoscope!!!!!!!
    EDIT: Missed Rifledrivers post!!!!
  19. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    Why not remove all the belts. Start engine. If the noise is gone, it's one of the belts or its tensioner. Put a belt on and re-tension. Restart engine and listen, etc, etc.
    I would not remove the timing belts for this test.
  20. Mark Young
    Mark Young Rookie
    Sep 5, 2018
    17
    lawrencetown NSCanada
    Mark Young
    HI
    I just want to say that I am far an expert on what could be wrong with your car. I live
    in Nova Scotia Canada and have own my 308 for over 16 years.
    Yesterday I decided to take it for its last drive of the year, it was -7 C but the roads
    were still clean of salt ( not today). snow flurries were forecast,
    I have discovered that a 308 can make a lot of scary noise until it warms up.
    It took 10 minutes just to get the temps to start coming off the pegs.
    I am just sending this thread because I envy you and your temps. I hope that your problem
    is not to serious. My car is now in storage in a heated garage, I just lit a wood fire to heat the house.
    Any of you folks that live in the northern US know what I am talking about ( that's about not aboot).
    Good luck on your car:)
    Mark
