White Connector Wiring Issue Mondial 3.2 | FerrariChat
Discussion in 'Technical Q&A' started by moysiuan, Mar 2, 2018.
  1. moysiuan
    moysiuan F1 Rookie
    4,239
    Canada
    I am replacing the white connector to the fuse board, after cleaning and replacing one of pins on the wire. This is the vertical right white connector which has 8 wires going into the 10 wire connector, the bottom two connectors being blank. Although I wrote down each wire colour in the correct order, stupidly there are two fat red wires which I just labeled red. From the top of the connector going down they would be in position 5 and 6 on the connector. The wires look identical. How can I replace these wires in the correct spots, any way I can tell which belongs on position 5 and which in 6? If I get them reversed, might it work out anyways? Help me fuse box experts!
    1988 3.2 Cab Swiss model
    I also have this post in the Mondial section, but posting here as probably the same for 328 and Testarossa, I think the two thick red wires are both to the ignition relays, but I am not sure enough.
  2. Steve Magnusson
    26,931
    No need to worry about it -- they are both +12V power from the battery to terminal 30 of the ignition switch so swapping them makes no difference.
  3. moysiuan
    moysiuan F1 Rookie
    4,239
    Canada
    Thank you, that makes sense!
  4. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,739
    Argent/Brasil
    Guido
    Correct....2 cables are +12V from battery.
    When loosing the other white plugs, make shure you put a small wire around all the wires like on the picture to avoid mixing them up...there are other plugs with the same colored wires.
    Guido
    moysiuan likes this.
