White residue on radiator reservoir 2004 360 | FerrariChat
Discussion in '360/430' started by Doctodd, Aug 12, 2023.
  1. Doctodd
    Doctodd Rookie
    Mar 12, 2022
    5
    Hutto Texas
    Todd Riggan
    I am getting some dry white residue on my radiator reservoir. I have wiped it clean and it reappears. I do not see any seepage of liquid. I am planning on replacing the cap incase there is a crack that I cannot see. Temp is running normal. I appreciate your thoughts.
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,411
    The Cold North
    Tom
    Change the cap..drive .enjoy..life is short
  3. 05F430F1
    05F430F1 F1 Rookie
    2,930
    Fort Lauderdale, Florida
    Todd
    My guess is that you are not actually cleaning it off... plastic stains and I bet when you 'clean' it, it disappears with product on it... but then after it totally dries and the heat gets to the cap, it shows back up again... does that pattern and location of the stain look familiar? same each time, I bet? Meaning, it's probably not happening again or leaking. It happened once, stained and shows back up in same spot and pattern once hot and dry... like tbakowsy said, buy a new cap and replace it.
    robertjskelton and KC360 FL like this.
  4. vrsurgeon
    vrsurgeon F1 World Champ
    15,974
    Charleston, SC
    Curt
    Bad cap as above. $50 to 60. Get and replace.
    EastMemphis likes this.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,801
    Central NJ
    Dominick
    +100
    Buy two and replace every 5 years ..crap caps
    tbakowsky likes this.
  6. hessank
    hessank Formula 3
    1,764
    Canada, Florida
    Fred
    Where?
    (credit card in hand)
  7. AandSC
    AandSC Formula Junior
    792
    Jax, FL
    Allen
  8. vrsurgeon
    15,974
    Charleston, SC
    Curt
    hessank likes this.
  9. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,661
    England
    Mark
    Quite likely to be the cap but make sure that you aren't overfilled.
    Doctodd and flash32 like this.
  10. Scottslaw
    Scottslaw Formula Junior
    Just for reference, even after I replaced my cap with a new oem one, I still sometimes get a very small amount of residue. I think its just a not-so-robust design. But if not spewing or leaking everywhere, you are probably fine.
    Doctodd likes this.
  11. Sergio Tavares
    Sergio Tavares Formula Junior
    Nov 15, 2018
    853
    Sergio Tavares
    is the cap plastic?
    SMH
  12. Doctodd
    Doctodd Rookie
    Mar 12, 2022
    5
    Hutto Texas
    Todd Riggan
    Yes plastic cap. I have purchased a new one and haven’t replaced it yet. Thanks for all the replies.
  13. anotherred360
    anotherred360 Karting
    Jan 10, 2015
    225
    Atlanta
    CTJ
    Chase the hose on the reservoir cap down to a small bracket that holds it and some other hoses in place. When it's not secured, a rather long run of hose becomes supported by the right angle joint at the cap, resulting in the seal getting tweaked as the hose moves around under bumps and vibrations. At least, that's what appeared to be happening on mine. I haven't driven long enough since re-securing the hose to be able to tell anything has changed, and am waiting on a new cap to get here since mine was already leaking slightly before noticing it.
  14. RedNeck
    RedNeck F1 World Champ
    10,173
    The CSA
    Me
