white smoke? | FerrariChat
white smoke?
Discussion in 'Technical Q&A' started by batman360, May 12, 2012.
  1. batman360
    batman360 Rookie
    Jun 8, 2009
    18
    Hey guys
    Just wondering if you could shed some light on something for me..Recently had my 360 F1 serviced. Everything great up to date on all services. Just refilled gas and right afterwards the car started letting out a puff of white smoke for a few seconds then gone. It seems to still do it on cold starts. If I cut the car off and start a few minutes later no smoke. Any ideas?
    Thanks in advance
  2. OptimusPrime
    OptimusPrime Formula Junior
    May 10, 2011
    291
    Florida
    Tom
    Sounds normal to me. Make sure to check oil when warm as this can also happen if there is to much oil in engine. Also, if there is white powder at exhaust pipe sign that cats are going out.
  3. zackspeed
    zackspeed Karting
    Nov 4, 2003
    67
    AZ
    Zack
    Not normal. Check the oil level. Engine idling with oil temp hot enough for the dipstick cap to burn your hand. Anywhere between the lines is ok. If it is over at all it can aerate and then gets sucked into the intake manifold.
  4. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,272
    Seattle Area
    Dave
    OP: Welcome to F-Chat :p:p
    Jedi
  5. batman360
    batman360 Rookie
    Jun 8, 2009
    18
    Not sure if you guys are familiar with 44K fuel additive, RF - 7, and MOA oil treatments. Anyways the Ferrari tech recommended and added these three during the last visit a week ago. Something about cleaning out the engine. Not sure but would any of these cause the puff of white smoke?
    Also no check engine lights and car runs great I have had it for 5 yrs.
    Happy driving season to all
  6. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,724
    White smoke is generally associated with water in the combustion chamber.
  7. Papa G
    Papa G Formula 3
    Dec 29, 2003
    1,406
    Condensation? or coolant?
  8. batman360
    batman360 Rookie
    Jun 8, 2009
    18
    Any chance the 44K fuel additive, RF - 7, and MOA oil treatments the Ferrari tech recommended and added during the last visit a week ago caused the puff of white smoke?
    I started the car today several times the first time there was a little smoke nothing like what I saw yesterday. But no other times after.
  9. alvav
    alvav Karting
    Apr 27, 2012
    123
    Montreal, Canada
    Leonidas Vavougios
    White smoke is usually coolant; not good (head gasket). Blackish tends to be rich fuel to air mixture (most easily fixed), and blue is for burning oil (also not good).
  10. BOKelley
    BOKelley Formula 3
    2,350
    Au'n Colorado
    Brock
    if you detect a rather sweet smell from the white smoke, it is coolant burning. A lot of times, it disappears as soon as components heat up and the leak is temporarily sealed up.
    Brock
  11. batman360
    batman360 Rookie
    Jun 8, 2009
    18
    Brock the tech added the below would any cause the issue?
    44K fuel additive, RF - 7, and MOA oil treatments. Also did a coolant flush and fill at the time
    Any suggestions. What happens overtime?
  12. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    #12 FerrariDublin, May 13, 2012
    You could google all three additives to see if there are any tell-tale pointers to look out for but I'd suggest you just drive that tank of fuel and additives out of her while monitoring the coolant level.
    Often we see things after service work has been carried out because we are "looking" for things.
  13. batman360
    batman360 Rookie
    Jun 8, 2009
    18
    Not sure googled earlier and saw a few posts about white smoke when the additives are being worked through the system. Hopeful thinking I guess.
    Car has full power, no leaks and no warning lights to indicate trouble for now. Maybe will call my dealer tomorrow to get thoughts. I think sometimes I worry too much, I guess if it is worse I will repair what needs repair. I don't track or run the car hard so hopefully nothing blows up
    Tomorrow is a new day
  14. Glassman
    Glassman F1 World Champ
    So the car runs and drives fine??????? I'd say drive it until something breaks or becomes obvious. Or do what I do and keep it in the garage where no harm can come to it.
  15. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    Just for the records, water does not make smoke: it makes steam!
    If it is white, has no odor and disppears quickly into nothing, it is steam
    If it is kind of light bluish has some odor and tends to linger a bit, then it is moke and it comes from oil, not from water or from coolant.
    If it is indeed from oil (and from your description it sounds so) and you see it at cold start only, it is most likely oil seeping down from one or more valve guides and collecting on top of a piston.
    You only see it at cold start because the seeping is little and it takes time to collect into a combustion chamber (i.e. overnight).
    You do not see it at warm start because it only happens over time and when the engine is cold.
    You probably do not need to worry about it yet, but you should keep an eye on it and watch also the oil consumption.
  16. OptimusPrime
    May 10, 2011
    291
    Florida
    Tom
    Thanks Jedi, tough crowd here. just got to remember that "success has many fathers, and failure is but a lonely orphan".
  17. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Yes and mine on occasion takes a green pee on the garage floor.....so? Welcome to the mysteries of Ferrari physiology. It would seem to me IMHO that it would only be a "real" problem if it was continuous or happening with more and more frequency. Remember that one of the combustion products of gasoline is H2O that will condense in the exhaust system and re-vaporize at a certain temperature (~100C or ~212F) on start-up perhaps this is what you are seeing? And the visibility of it will vary with altitude and humidity also.
  18. donho
    donho Karting
    Oct 11, 2006
    154
    Naples, FL
    Michael
    That engine is very sensitive to oil level. My guess is that yours is a little too high. The additives, while unlikely a problem, probably pushed your level over the top. Make sure that the level is below the line when the engine is HOT.
  19. batman360
    batman360 Rookie
    Jun 8, 2009
    18
    Just an update in case anyone has this issue in the future. It was the addition of the additives . When the Ferrari tech added the oil additives he did not compensate by filling with less than 10 quarts. Either way the dealer drained out some oil today and all is well. It was only a little over the top line.
    Happy driving F-chatters
  20. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    Thanks for the feedback Batman. Adds to the library of experience. Good news!
  21. BOKelley
    BOKelley Formula 3
    2,350
    Au'n Colorado
    Brock
    Very true, steam is not smoke and has not odor. It is a normal combustion product from burning gasoline, i.e. condensed steam can be seen as it forms in a cold exhaust system and will disappear when temperatures rise.That is why one has to differentiate between steam and burning coolant (glycol) which does produce a white, sweet smelling smoke where the sweet smell is the usual telltale sign. Burning glycol also tends to produce a lingering smoke that dissipates rather than re-evaporating as does the steam.
    Brock
  22. chipbiii
    chipbiii F1 World Champ
    11,026
    SC
    chipb
    Let's be careful about that. I took my 2004 360 in for an oil change and talked to a master mechanic who is popularly known on the North Carolin/South Carolina blog and he demonstrated to me first hand that WHITE smoke is usually OIL, not coolant. He had just finished rebuilding the engine on a BMW and he invited me to witness the engine start up process. The engine was started and immediately steams of white smoke billowed out of the pipes. While I was watching he informed me that the white smoke was a normal part of the process to burn off the new oil throughout the system and would typically continue to burn anywhere from five to fifteen minutes. After that the engine exhaust smoke disappeared and the engine was good to go.
  23. BOKE
    BOKE Beaks' Gun Rabbi
    33,965
    600 East Fremont Street
    Lucky
    White Smoke = A New Pope.
    Almost always white smoke is oil.
