White sparkplugs in front row, black in rear?? | FerrariChat
Discussion in '308/328' started by Gisle, May 20, 2013.
  1. Gisle
    Gisle Rookie
    Jun 4, 2011
    30
    Norway
    Gisle Platou
    Hello i am the lucky owner of a carbed 77 GTB .
    When i had the annual change of sparkplugs, i noticed that the front row sparkplugs where almost white (to lean setting?), and the rear row black (to rich setting?). Is this; A carb issue? Ignition? One camshaft a notch wrong? - all of the above or maybe something else?
    The car seems to run ok but I am a little bit unsertain about the engine sound, i believe it is not as sweetsounding as it used to be.
    I have noticed a little sweat from the rear carbs.
    Last year i removed the restricting sound silencer in the filterbox inlet. No dramatic change of performance but it seemed moore eager / happier above 6500RPM. (Beautiful carb sound)
    Someone been there before? I would like suggestions where to start.
    Gisle
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,849
    Atlanta
    John!
    Check the ignition on both banks first. Is this a US or Euro car?
  3. Gisle
    Gisle Rookie
    Jun 4, 2011
    30
    Norway
    Gisle Platou
    Hello, it is a US, twin distrubutor without airpumps or cats. The second pair of points is removed.
  4. hoverland
    hoverland Formula Junior
    Aug 14, 2010
    265
    Norway
    Harald Ø
    Checking and comparing dwellangle & dynamic ign. timing for forward/aft bank will give you good information with minimum effort.
    Harald
  5. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    I'd say to look into the rods connecting the front carbs to the rear.
    Pick up a carb airflow meter if you don't already have one and do the carb sync process. It's spelled out rather minimally in the service books that you may have, or there's an adequate tutorial on Birdman's Ferrari site.
  6. Fairview
    Fairview Formula 3
    Mar 16, 2009
    1,109
    Waynesboro, Virginia
    Jeff Ward
    And if your choke control is still connected, make sure the choke lever arms on all the carbs are going back fully off. An out of adjustment choke control linkage could definitely make two carbs on a bank richer than the other two.
  7. Gisle
    Gisle Rookie
    Jun 4, 2011
    30
    Norway
    Gisle Platou
    Thanks to all of you.
    I will check out your suggestions next weekend.
    Gisle
