355 - Who has an early 355 equipped with a single-piece (center) undertray? | Page 2 | FerrariChat
355 Who has an early 355 equipped with a single-piece (center) undertray?
Discussion in '348/355' started by ShineKen, Jan 26, 2023.
  1. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    559
    Tempe
    Jon
  2. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    The one on the underside of the press photo does not have the naca ducts either side like all the ones shown so far either.
    ShineKen likes this.
  3. ShineKen
    ShineKen Two Time F1 World Champ
    20,157
    Southern California
    Nostradamus
    Since I am on my phone, the link doesn’t direct to the exact post you are referring to. Can you post the pic here?
    I recall the part no. on the undertray was written with some marker, not etched.
  4. zstyle
    Jun 28, 2007
    559
    Tempe
    Jon
  5. ShineKen
    20,157
    Southern California
    Nostradamus
    Correct. Another detail noticed on mine is only the center duct had mesh installed. Two side ducts did not have any mesh.
  6. ShineKen
    20,157
    Southern California
    Nostradamus
    Just stumbled across an old thread where @INTMD8 asked why his undertray did not have a “notch” seen in the early/promo single-piece undertray.
    https://www.ferrarichat.com/forum/threads/355-notch-in-undertray.483409/
    I think I have a plausible explanation. Concept of single-piece undertray was to be able to service oil without having to remove the undertray at all. There is a square cover (that’s actually made out of metal, not fiberglass) that when removed, allows drain plug access with torque wrench and your hand to tighten or loosen. The “notch” is probably both for visibility (locating the drain plug) and room for some specialized funnel to capture/guide the oil when it shoots out.
    Whether this can be done conveniently on jack stands/low rise lifts is another matter :). I think with the rear right wheel removed and a jack placed carefully and strategically out of the way it might be possible.
    The notch and the square cover was ditched as soon as it became a 2-piece design.
    Thoughts?
  7. ShineKen
    20,157
    Southern California
    Nostradamus
  8. ShineKen
    20,157
    Southern California
    Nostradamus
    zstyle likes this.
  9. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,771
    The NACA ducts are from the challenge conversion kit.
  10. ShineKen
    20,157
    Southern California
    Nostradamus
    I believe he is referring to the side naca ducts on the center piece undertray, not the rear diffusers.
  11. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Correct
  12. moretti
    moretti Five Time F1 World Champ
    Nov 1, 2003
    59,756
    Australia
    I got a bit lucky some years ago handing all of my undertray to a local race car start up and asking for them to make carbon fibre versions of my original undertray pieces ...... they charged me AUD$700 if they could use my parts for adverising their business
    Prior to the carbon undertray being fitted I broke lots of small pieces off the fibreglass undertray, now just sparks when I bottom out :)
  13. ShineKen
    20,157
    Southern California
    Nostradamus
    Do they still have the molds?
  14. moretti
    Nov 1, 2003
    59,756
    Australia
    Not sure mate, was done about 8 years ago but I'll ask for you :)
    They used my (challenge) parts to create them so will have scoops and ducts "normal" 355s may not have
    Mine was a 1996 challenge
  15. ShineKen
    20,157
    Southern California
    Nostradamus
    All I need is pics or contact info :)
  16. ShineKen
    20,157
    Southern California
    Nostradamus
    Front left challenge undertray (as shown above) has vents. Center piece undertray/s are the same as a standard car. Your car probably had the 2 piece undertray.
  17. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
  18. ShineKen
    20,157
    Southern California
    Nostradamus
    The great thing about having a mold is an original can be placed back into the mold for repair. Chunks missing can be added on while staying within original dimensional spec, while retaining the original undertray. It's a nice solution as long as someone is willing to ship back and forth. Only worth it for heavy damage though, where large chunks are missing. I highly doubt anyone's early undertray is in great original condition. They were fairly flimsy and fragile to begin with.
  19. ShineKen
    20,157
    Southern California
    Nostradamus
    The most damage prone areas as far as I can tell are the outer side edge walls.
    308 GTB likes this.
  20. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    I found that to be the case too...
  21. ShineKen
    20,157
    Southern California
    Nostradamus
    Would be a good idea to reinforce those areas with carbon fiber for added strength.
    308 GTB likes this.
  22. ShineKen
    20,157
    Southern California
    Nostradamus
    If you click on the upper right at #9119, it will lead you to a page where you can grab a direct URL. This will go directly to the post mentioned as viewers are seeing different things depending on what they are viewing with.
    https://www.ferrarichat.com/forum/posts/148510588/
    zstyle likes this.
  23. ShineKen
    20,157
    Southern California
    Nostradamus
  24. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    They're using Kevlar for reinforcement of those prone areas, Ken. Same for the fastener holes.
  25. ShineKen
    20,157
    Southern California
    Nostradamus
    Even better :)
    308 GTB likes this.
