Who leaves their F1 in neutral while parked in the garage? | Page 2 | FerrariChat
Discussion in '360/430' started by caymangone, Apr 28, 2019.
  1. KC360 FL
    KC360 FL Formula 3
    Jun 20, 2017
    1,695
    Melbourne Florida
    KGC
    I thought I read in the manual that it was preferable to put the car in neutral, set the parking brake and step on the brake pedal as you turn off the ignition. That's what I do. I have no aversion to setting the parking brake as my 360 gets driven at least once a week. But I understand that the brake can be a little sticky if set for long periods of time.
    Solution to this: drive and enjoy your Ferrari regularly.
    Hazim, Apollo 11, E60 M5 and 3 others like this.
  2. ARMfastlane
    ARMfastlane Rookie
    27
    Plymouth, MI
    Adam
    I recently took delivery of my first Ferrari (‘08 F430) and the delivery guy (from a Ferrari dealer) advised me to put the car in neutral, and set the parking brake before turning it off. Then upon startup the car is in neutral and ready to go. There is a long beep on key-off and initial key-on with this process, but he said it can extend the life of the clutch. After reading this post it seems like personal preference.
  3. mello
    mello F1 Veteran
    5,041
    CA Bay Area
    Steve
    I also leave it in neutral when parked in the garage. I also pull on the e-brake (unlatched) once in a while when coasting to give the pads a chance to set in with the wear of the rotors.
  4. F5506M
    F5506M Formula Junior
    Nov 3, 2003
    920
    New Jersey
    Ray
    In gear and no parking brake.
    cole328 likes this.
  5. Silentnoiz
    Silentnoiz Karting
    Nov 18, 2017
    121
    Nashville
    Silent Noiz
    I follow the owner's manual and shut the car off in 1st gear. I don't use the parking brake in my level garage, but do use it when parked anywhere else (that has a slight grade or greater).
    I don't think there would ever be an issue with the car lurching forward for some reason when starting it when left in 1st gear (if the car didn't shift it to neutral for some reason)...I can sit on a level surface in 1st gear with the car running with no brake and it doesn't lurch/move forward.
  6. tazandjan
    38,054
    Yup, several owners have had their Ferraris lurch forward when in 1st gear and trying to start with a low battery. The OM says to put her in neutral for starting. Not like that is something difficult to do.
    E60 M5 likes this.
  7. becausephilchow
    becausephilchow Formula Junior
    Aug 26, 2016
    543
    Hong Kong
    I always put mine in Neutral before I turn the car off. Never had any issues at all.
  8. CWR01
    CWR01 Rookie
    Sep 9, 2017
    16
    Craig Rundels
    I usually keep mine in 1st but regretted doing that when my F1 pump went out. It was impossible to put the car into neutral for towing. The car had to be put on dollies to get it out of parking and onto a flatbed. In most normal cases though I think it is preferred to leave in gear when parked.
  9. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Thanks everyone for sharing your preferred parking method.
    Mine is simple, I follow the Owners Manual. That is, set the car on 1st gear or R before turning the engine off, then also set the parking brake before exiting the car. This is for ultimate safety.
    Then to start the engine pull on both paddle shifters to set the gear in neutral, ensure N is displayed before pressing Engine Start button.
    I was born and raised, and trained not only safety first but safety always.
    If you get into a habit of leaving the car in neutral and not setting the parking brake on and then leave the car just please make sure your parking spot whether at home or visiting a friend or at the Mall or side street, or anywhere is perfectly flat and level.
    Just ask my former neighbor. His garage floor was not perfectly level. Make a long story short his car rolled out of his garage and landed across the street damaging his neighbors house. Luckily no one got hurt and it's not a Ferrari.
    DefunctNeurons and Apollo 11 like this.
  10. albkid
    albkid Formula Junior
    Jul 1, 2016
    318
    Jim
    As a decades-old driver of 3-pedal cars, I would always put the car in neutral when parked -- except on an incline when 1st was selected and the parking brake engaged.
    The surface of my garage is level so neutral is routinely selected when parked therein. No need to set the parking brake.
  11. 67bmer
    67bmer Formula 3
    1,197
    MD
    You should ALWAYS park your car in neutral!
    Just because its a Ferrari, does not mean it will not get hit in a parking lot, depending on how/where you park it.
    I have dismantled several BMW transmissions and have found a single chipped gear tooth! That comes from getting hit while left in gear.
  12. tazandjan
    38,054
  13. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
    Okay, I guess there's now a consensus on what to do: Leave the car in gear or in neutral before you shut the car off. Then, apply the parking brake or do not apply the parking brake before you exit the car. Then, to start the car, either leave it in gear because the car automatically shifts to neutral, or put the car in neutral yourself. Got it! ;)
    artsd, bupilot, kes7u and 4 others like this.
  14. _JERRY_
    _JERRY_ Karting
    Feb 1, 2016
    174
    Singapore
    Jerry Ng
    #39 _JERRY_, May 15, 2019
    Park in 1, no? If I’m not wrong , the car will force start in neutral regardless
    Don’t think it’ll do much wear to the car in either scenario, my idea has always been parking in 1 gives it one additional layer of “brake” in case of weird freak accidents. Heh
    I think another aspect to consider would be tuning your habit. If you always park in 1, when you actually take the car out , you’re more likely to habitually park in 1.
  15. PVEferrari
    PVEferrari Formula Junior
    You hit the nail on the head! ;-)
  16. tazandjan
    38,054
    Or you could actually read the OM. No, never mind, dumb idea.
    whatheheck, E60 M5 and Apollo 11 like this.
  17. ttforcefed
    ttforcefed F1 World Champ
    18,873
    cant wait to see how many posts this thread gets!!!
