Who uses two monitors on their desktop? | FerrariChat
Discussion in 'Other Off Topic Forum' started by PeterS, Nov 9, 2004.
  1. PeterS
    PeterS Five Time F1 World Champ
    52,129
    Goodyear, AZ
    PeterS
    I saw an ad for a product that junctions two USB monitor cables into one CPU and thought it would be cool to have two live monitors on my desk. Just seeing if anyone has this setup and if their are any mouse problems in operating the two screens.
  2. LAfun2
    LAfun2 Three Time F1 World Champ
    Oct 31, 2003
    39,248
    California
    Ryan
    I use 2 19 inch monitors side by side, for a huge viewing space. Basically it is all one screen separated by two monitors. Moving mouse from screen to screen is not a problem. You use it just like you use a regular one monitor computer. Have had this setup for about 16 months, and it works great.
  3. redhead
    redhead F1 Rookie
    Dec 26, 2001
    4,869
    ~Red~
    tvrfreak has this same set up as well.
    When at home, I have a 19 LCD panel(that is a TV as well) that I plug my laptop into and watch movies off the laptop on the wall. I keep the lap top screen open and can surf while watching a movie. very easy, and only 2 cables.
  4. PeterS
    52,129
    Goodyear, AZ
    PeterS
    Could you please post of pic of your desktop so I can get a visual? In trying to understand your setup, does the setup split a single screen?
  5. KennyH
    KennyH F1 Veteran
    Aug 13, 2001
    5,238
    NYC
    Kenny
    I will as soon as I get back to my dorm room. There are two modes via the ATI software- 1 being the second monitor just mimics the first- and the 2nd mode being that you it physically doubles your desktop area- you can drag anything over to the other monitor as if it's the first- very easy to set up and much more convenient...
    I can't work with one monitor anymore, I highly recommend it.
    BTW- I have mine set up through a dual monitor capable AGP (?) card in my laptop..
  6. LAfun2
    Oct 31, 2003
    39,248
    California
    Ryan
    #6 LAfun2, Nov 9, 2004
    Your wish is my command, sir.
  7. darth550
    Jul 14, 2003
    61,137
    In front of you
    BCHC
    BRAND NAMES, RYAN, WE NEED BRAND NAMES!!!!!
    DL
  8. damcgee
    damcgee Formula 3
    Feb 23, 2003
    1,864
    Mobile, AL
    What screen resolution do you use? I bet it is tough to get a good backround in 2048 x 768 or something like that.
  9. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    USB? doesn't need to be USB. just get a dual head video card in order to set it up correctly. I've used this in the past and it is great. I just couldn't take the heat of two 21" monitors in the room anymore. the electric bill went down significantly once I settled for one 19" lcd.
    ati has some dual heads as well as nvidia. searching here: http://newegg.com/app/manufact.asp?catalog=48&DEPA=1 for 'dual' in the keyword should bring up a handful of results at a cheap cost. some are under 60, while one I recently purchased for an individual here at work was 73 bucks. not that much for basic desktop (non-video/non-rendering) applications.
  10. Malfoy
    Malfoy Formula 3
    Mar 22, 2004
    1,960
    Hampton, VA
    Can't imagine being w/o it.
  11. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
  12. DropGems
    DropGems Formula Junior
    Nov 4, 2003
    407
    Atlantic City, NJ
  13. bludevil12
    bludevil12 Formula 3
    May 12, 2004
    1,930
    Northern VA
    David L.
    A couple of questions. If I am using one monitor right now, what do I need to upgrade to 2/how much would this cost?? Thanks.
  14. gentry
    gentry Guest
    I have a 19" KDS CRT and a 23" HD Cinema display both hooked up to my G4. The new G5 is going to have one 30" HD. The 19" died after this photo was taken about a month or two ago, and has been replaced by a spare 17" I had sitting around.
    Does anyone know of any KVMs that support Apple and PC as well as ADC connections?
  15. gentry
    gentry Guest
    You just need a dual headed video card, most of the good ones now are. And a second monitor.
    Pretty much any new nVidia or ATI card will support dual monitors. You might need an adapter, because they generally tend to have one VGA and one slot of another type.
    GL
  16. Z0RR0
    Z0RR0 F1 Rookie
    Apr 11, 2004
    3,470
    Montreal, Canada
    Julien
    #16 Z0RR0, Nov 9, 2004
  17. LAfun2
    Oct 31, 2003
    39,248
    California
    Ryan
    Zorro
    LMAO! But you forgot to put in the corner something like "Ryan748.com" or "Ryan996tt.com"
    Now that would complete the pic :D
  18. Z0RR0
    Z0RR0 F1 Rookie
    Apr 11, 2004
    3,470
    Montreal, Canada
    Julien
    Damn!!!! I knew I had forgotten something ... must have been the stupid smile on my covering the corners of the pic!!! LOL
    This guy also has a multi screen setup ... and an awesome one, thank you!!!
    http://stresstest.2y.net/images/deskrefit/PB032107.jpg
  19. tvrfreak
    tvrfreak F1 Rookie
    3,879
    Arkansas
    F K
    An AGP dual video card is the best way to do this, but you can do it cheaply by just adding a second video card to your computer and hooking up your second monitor to the second video card. The second card usually needs to be PCI, not AGP.
    Your computer should recognize both cards if you are running Windows XP, and you can go to your video properties (right-click on your desktop and select properties) and define the monitors' positions relative to each other so that the computer knows how to handle the cursor and windows when they get moved to a monitor's edge. Peter, I am including a screen shot to show what you need to look at and set in order to get the cards and monitors to work.
    I can't imagine working without a dual monitor setup as I often have to refer to several documents. Having them all open and visible at the same time really helps.
    Here's my setup (2 Dell 20" flat-panel LCDs running at 1600X1200 each)...guess which car I like! And no, the pictures are not hung crooked...the camera lens just make them seem that way :):
  20. redhead
    redhead F1 Rookie
    Dec 26, 2001
    4,869
    ~Red~
    Damn Lefties.
    :D
    ((talking about the mouse))
  21. jsa330
    jsa330 F1 World Champ
    10,046
    75225
    Scott
    I have an ATI Radeon dual-head video card that I bought about three years ago to use with my ArchiCad architectural software. I had it hooked up to a Dell 21" CRT for my main CAD desktop/2D drawing area and a GEM 17" CRT to the right for the 3D window. This video card was less than $150.00 installed at CompUSA and performed very well. My main problem was poor processor speed for the 3D app. and my wife now has that computer. I now have a Dell notebook with much greater capability but with only single monitor display ability (my wife bought the notebook and then decided she didn't like it). It's hooked up to a 19" Samsung LCD flatscreen that I just bought. I need to see about a dual-head card now. Its a great thing to have for apps that support it.
  22. coolestkidever
    coolestkidever F1 Veteran
    Feb 28, 2004
    5,538
    NJ
    Patrick
    I was waiting for it, good ****
  23. mike550
    mike550 Formula Junior
    Aug 20, 2003
    859
    California - LA & SF
    Mike G
  24. bottomline
    bottomline Formula 3
    Mar 10, 2004
    1,149
    Denver, CO
    Bijan
  25. mike550
    Aug 20, 2003
    859
    Mike G
