430 - Whoops. F1 Problem! | FerrariChat
430 Whoops. F1 Problem!
Discussion in '360/430' started by Enzo Sebastian, Sep 21, 2024.
  1. Enzo Sebastian
    Enzo Sebastian Formula Junior
    298
    Amsterdam
    Laurence Sebastian
    Hmm sad day; good friend of mine and I wanted to drive out F430’s for an early cup of coffee after a spirited drive on one of the last sunny days here in The Netherlands.
    Unfortunately, going up on the freeway, doing 90km/h’s, there it was: a long beep. With a very nice red ‘Gearbox error’ light in my dash popping up. FML. Now, I must have done some good prayers last night because we were 10 kilometers away from home and I got to drive everything in 3rd gear without issues: all lights turned green on time! My God, my heart was throbbing.
    I immediately noticed that I was able to downshift, but shifting upwards was not possible. I’m so, so glad the traffic and traffic lights were helping and my good friend lead the way carefully for me, eventually I got to park the car perfectly on my driveway again haha.
    Now, you might believe this or not, but the first day I had this car (4 years ago exactly) I had the same issue! Well, almost. After hitting a bump on the way, the car beeped, the same F1 error light came on, the car shifted to N and would not shift at all anymore. Had to push the car into a parking lot to be towed : it appeared to be a sensor, a pretty expensive one, but okay, I could drive again!
    Now exactly 20k km’s later, I have a different issue. The car goes perfectly from Neutral to 1st and to Reverse. However, not any further than 1st.
    The pump cycles are all normal and the pump sounds normal as well.
    This coming Monday the dealer is going to pick the car up, but because I like losing sleep over these things, I’m dying to hear what you guys are thinking. The garage (Ferrari specific) does not think it’s the relais as then nothing should happen at all. But it’s clearly not holding pressure in anyway. Actuator? E-diff? Something else?
    I don’t have any codes pulled as I don’t have a reader here, but I can keep you guys posted!
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,928
    Central NJ
    Dominick
    Most likely shift sensors .. potentiometers
    To eliminate pressure issue
    Do these timings pump on /off
    Key on /engine off
    Key on / engine on
    Key shifting ..how many shifts from 1 to n to 1
    25 mph straight without shifting or turning
  3. Enzo Sebastian
    298
    Amsterdam
    Laurence Sebastian
    Wait, the key on/engine off and 25mph test, you lost me there
    Racer_X likes this.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,928
    Central NJ
    Dominick
    Separate tests ..4 tests in all
  5. Enzo Sebastian
    298
    Amsterdam
    Laurence Sebastian
    I understand, but you want me to drive 25mph in first gear, to see what? What happens? Nothing will happen, it won’t shift.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,928
    Central NJ
    Dominick
    Sorry to see how many mins the pump stays off ..
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,928
    Central NJ
    Dominick
    You can PM me and we can setup a WhatsApp call if you like
  8. Enzo Sebastian
    298
    Amsterdam
    Laurence Sebastian
    Ahhh wait I might do that thanks! Problem though is my time is very limited tomorrow and the car is being picked up on Monday morning..
  9. Pete Schweaty
    Pete Schweaty Formula Junior
    May 21, 2014
    281
    Flash helped me greatly when I had an issue. He is probably one of the most knowledgeable people out there when it comes to the f1 system. He spent well over an hour on the phone with me going through various diagnostics test. Incredibly helpful and generous guy. Definitely take him up on the offer!
    tomw, L1MTD, mb5 and 4 others like this.
  10. mvaldezf60
    mvaldezf60 Karting
    Feb 16, 2009
    211
    California
    Agreed with Pete, Flash helped me diagnose and walked me through fixing two separate issue I had with my F1 System. This was with my 360. To say he is very knowledgeable with the F1 system is an understatement.
  11. Enzo Sebastian
    298
    Amsterdam
    Laurence Sebastian
    Update!
    Car was picked up yesterday and this morning came the message that the car was running as new again! Apparently the potentiometer (?) needed replacement. No clue yet what that does haha but I’m happy they fixed it!
    Picking the car up soon yay!
    Qavion and flash32 like this.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,928
    Central NJ
    Dominick
    I called it in post 2 ..:)
    Glad it all worked out
  13. Enzo Sebastian
    298
    Amsterdam
    Laurence Sebastian
    Haha Dominick yes you're very right! True, true.
    Just a question; what does the potentiometer(s) do? Also: given that nobody wants to have the horrible long error-beep and the car not moving at all or partially functioning, what other F1-components can be replaced in order to prevent this from happening? My car is at 80.000km's now and 20k km's ago the cluth, flywheel and other parts were replaced. I had a sensor replaced the moment I picked up the car and now the potentiometer. What would you advise in order to keep errors away as much as possible?
    flash32 likes this.
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,928
    Central NJ
    Dominick
    The two potentiometers thru voltage tell the TCU where the imaginary "stick " is withing the gate of the transmission...show the position of actuator as it relates to what gear it should be in
    I am have never been an advocate telling people to change things before they give a sign of an issue .. the biggest reason, besides the expense is that at multiple times the new parts were either defected or lasted only a short period if time.
    This actually happen a few times with new sensors and solenoids for the F1 system.
    So my advice is to listen for sounds or abnormalities that you normally don't hear, get the car checked by a qualified person in a regular basis, do your maintenance and have a good time trucking company ready to help if needed
    The F1 system has limp mode for some of the issues that may come up as you saw with bad sensors ...other issues will leave you without being able to start car
