Who's regularly performing these maintenance items? | FerrariChat
Discussion in '360/430' started by Michael Parks, Dec 2, 2020.
  1. Michael Parks
    Michael Parks Rookie
    Aug 23, 2018
    13
    Virginia
    Michael Parks
    I was looking at the maintenance schedule I created for the F430 according to what the dealer provided during my PPI a couple of years ago (see attached) and the following items caught my attention.
    Change A/C Filter - Evacuate system and install new filter and Freon, check oil level - Due every 15k miles.
    Replace accessory (Serpentine) belt - Due every 15k miles.
    Replace oxygen sensor - Due every 30k miles starting at 25k miles.
    Replace active charcoal trap (I'm assuming this is a fuel vapor canister) - Due every 30k miles starting at 25k miles.
    I'm curious how many people are doing this per the dealer schedule. I read a lot about fluid and spark plug changes but not things like flushing the freon every 15k miles or proactively replacing the 02 sensors every 30k miles. Just curious.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,954
    Isle of man- uk
    You might only get 6000 out of the pulley belt, depends on its age as well.
    A/c freon drier- unless you feel a drop in temp over the in and outlet pipes then leave it alone.
    Not sure on the O2 sensor or the charcoal trap
  3. 67bmer
    67bmer F1 Rookie
    2,956
    MD
    preemptively replacing an O2 sensor sounds stupid! Especially when they are so easy to get to and are not catastrophic failures. On a daily driver, they can go 100,000. I have coworkers that have never replaced their O2 sensors on commuter cars.
    armedferret likes this.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,897
    Central NJ
    Dominick
    I would say the belt only on the list
    Sent from my moto g(7) using Tapatalk
    ditpixs likes this.
  5. AandSC
    AandSC Formula Junior
    951
    Jax, FL
    Allen
    Three items I recommend replacing at least every ten years:
    F1 Hydraulic accumulator
    Charcoal filter
    Serpentine belt
  6. vrsurgeon
    vrsurgeon F1 World Champ
    16,526
    Charleston, SC
    Curt
    Serpentine belt will go for us 360 owners with every belt change. The rest as needed. Dealership PPI.. I have to go to the bathroom, can I borrow that?
    I'm surprised it didn't say replace both seats in the occupant compartment for leather wear.. ;)
    Red 27 and one4torque like this.
  7. 24000rpm
    24000rpm F1 Rookie
    im a cheap wad
    1. serpentine belt, inspection only. Replace only when its cracked.
    2. no o2 sensor replacement until it gives me a cel.
    3. a/c filter: clean them. replace only when it is real real dirty and would take more than 10 min to clean. never replace feon until a/c is no longer cool or the ac pump is giving a noise.
    4. charcoal canister: only when it gives me a problem when re-fueling.
    one4torque likes this.
  8. tazandjan
    39,163
    The AC filter is actually the receiver/dryer/filter that tries to keep water (and junk) out of the system. Changes were even more frequent on older Ferraris. Our AC systems are not the most modern.
  9. 24000rpm
    24000rpm F1 Rookie
    i see, you are talking bout the cylinder under the car.
  10. CoreyNJ
    CoreyNJ Formula 3
    2,443
    New Jersey Shore
    My Ferrari specialist mechanic changes the serpentine/accessory belt every two years or 12,500 miles according to his website as part of the F430 two year service (Biennial service). I will be having him perform that work this winter when I bring the car in for my new exhaust.
  11. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    The AC dryer is really inexpensive and keeps water from destroying the compressor. I would think that is one of the easier things to overlook but has good benefits.
    I just changed my serp belt and super easy w 15mm once the under car cover is removed.
