Who's removed the coolant hoses to do engine out? | FerrariChat
Discussion in '348/355' started by gobble, Feb 11, 2015.
  1. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    They seem impossible to remove. What's the trick?
  2. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,409
    Robb
    I hear small hands and much patience...
    I will follow your discoveries.
    Robb
  3. group77racing
    group77racing Formula Junior
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    take it to your mechanic
  4. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Talked to Dave and he was helpful as always.
    How would I feel about myself if I had to rely on a mechanic???
  5. WATSON
    23,842
    WI
    I asked the same question abut my engine out...Long extensions and some creativity.
    A knife works better...and new hoses later...
    What did Dave have to say?
  6. fatbillybob
    Aug 10, 2002
    29,188
    socal
    Loosen hoses on one end. When you lift the chassis off the engine craddle the hose come right off. Installation it the reverse. Zero force or bad words needed.
  7. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    A 3/4" x 3/4" x 2' piece of maple pushing from the back of the car while standing where the exhaust was did trick.
    This taking the engine out is harder than I thought it would be. I spend much of my time just staring at the car because even the best DIY I found is somewhat vague when describing the parts and steps.
  8. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,628
    San Carlos, CA
    Mitchell Le
    I slice the hoses and replace them.
  9. yelcab
    Nov 29, 2001
    13,628
    San Carlos, CA
    Mitchell Le
    The first time is hard. The second time is a breeze.
  10. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    seems thats the trick to every repair lol.... I look at everything I do as a challenge and keep grinding until I find the answer
  11. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Mark are you doing the engine out on your car now?
  12. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Yes last one was 5 years ago.
  13. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I meant are you doing it yourself? If so good on you. Post some pics along the way please. You have a 4 post lift and im interested in seeing how you do it. Thanks c
  14. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    I am. My plan is to drop the engine myself then bring a friend over who knows what he's doing to change the belts, time the cams and troubleshoot everything else. I have a friend who's a former Lambo tech and trust him with this. I have at least 100 pictures so far but have spent my time working and not posting. The engine isn't quite out yet. I'll post when I have a chance.
  15. group77racing
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    Whoah, you can't trust farm tractor tech...
    "all in fun here" :D
  16. yelcab
    Nov 29, 2001
    13,628
    San Carlos, CA
    Mitchell Le
  17. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    I do have close up pictures so far of every single joint and fitting and screw that's needed to be undone so it would make a good supplement to an instruction like "disconnect the vapor recovery hose". My first thought when reading some of the steps is where the hell is that?
  18. yelcab
    Nov 29, 2001
    13,628
    San Carlos, CA
    Mitchell Le
    Great. You are the 355 version of Peter Rychel with his 308GT4.
  19. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    +1 ....this is what I did.
  20. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    The hoses were horizontal so I was afraid to try that.
  21. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    I loosened the upper clamps on the body side of the hoses and the hoses just slid off as you raised the car with the hoist.
    When it came to re-assembly, I installed the water hoses on the motor (clamps slack) side and lowered the body slowly towards the motor.....when the hose and pipe were about to connect I reached in and lined up all the hoses and then continued to lower the body towards the motor. No issues.
  22. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    #22 cf355, Feb 13, 2015
  23. Rifledriver
    37,273
    Good choice. I have seen the expensive water pipes mangled doing that.
  24. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Is the consensus to drop the oil tank with the engine?
  25. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Can't understand why. The hoses slid off and slid back on with no issues.
    But I was controlling the hoist speed....very slowly.... a mm at a time.
