Why did Ferrari use belts instead of chains? | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by American Pie, Nov 7, 2007.
  1. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    You don't seem to recognize, or at least acknowledge that almost every one of the hundred-odd 'belt' threads you 'have no interest in reading' has had the belt vs chains topic brought up & extensively discussed. This 'belt thread' seems to have done a little better job of staying on topic than some of the others, but like the others, it's gone afield & gotten into personalities at times.
    The bottom line is still that only the Ferrari Engineers knew what the trade-offs were & what they regarded as the state of the art at the time, & we're 2nd guessing them.
  2. American Pie
    American Pie Karting
    Nov 3, 2007
    83
    Camarillo, CA
    Larry
    Thanks Verell for being one of the more cool-headed posters. If I had known this was such an explosive issue on FChat I never would have started this thread, because I don't want to cause any coronaries.
    Anyway, I've been going through many more of these "chains vs. belts" threads and think I can now summarize an answer to my original question. It seems that although belts were considered "state of the art" in the early 70s when the Boxers were being designed, they have not had the life expectancy (in terms of age, not mileage) that Ferrari originally expected. As Ferrari began to see high failure rates, over the years the recommended replacement interval was gradually adjusted downward. Finally, when that change interval reached three years, it was decided to just stop and go back to chains. That's why both the older models and the newest ones use chains.
    I originally asked this question because I couldn't understand why Ferrari would have designed their mid-engine cars (Boxers, TRs) to require a labor intensive, engine-out service every 3-5 years regardless of mileage. Now I understand why; they never anticipated the short life of the belts, and probably assumed these cars would get used a lot more which would require replacement due to actual mileage before age. If they had foreseen the relatively short belt life, they probably would have designed the cars with at least some type of engine access through the firewall to carry out the task.
    If this subject has truly run its course, let's just let this thread die. I can see now that this issue (cost of a major) is a big concern to many BB/TR owners and I'll spend some more time reading their posts (and using the search button, LOL) to keep learning as much as I can about the procedure. Thanks to all for your replies, and let's try to keep the forum fun.
  3. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Nice summary, & captures the most likely reasons. The cost of a major is also a big issue for non self-maintenance 3x8/Mondial owners as it's a higher % of the car's street price! For us self-maintenance types it's a weekend's work.
    I concur that this thread seems to have run it's course.
  4. Bradley
    Bradley F1 Rookie
    Nov 23, 2006
    2,831
    Lakewood, Colorado
    Bradley
    Artvonne,
    Your post wasn't very nice. Mr. Newman's welcomed the new person to F-chat and answered his questions politely.
    End of discussion.
    ~Bradley
  5. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    The real question wasn't why not chains, but why put the belts on the end of the engine you can't get too... Why couldn't they have put the belts on the back of the motor. The 430 has chains so that issue is gone there, and I just did the Mondial, but I do wonder.
    Art
  6. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Well, again in fairness - let Porsche serve as another modern-day example. I would just bet that there is little you can do with a Boxter engine for major service other than to pull it out of the car as well.
    Best comment of all here is - we were not the engineers, so we just do not know why they did things the way they did.
    So we have to live with it in the best spirits possible.
  7. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Hear, Hear!!!!
    In other words:
    "God grant me the Serenity to accept the things I cannot change.
    Courage to change the things I can and
    Wisdom to know the difference."
  8. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,606
    Pacific NW
    Anthony C.
    I may be wrong about this but I think it is because the cars in question (Boxer and Testarossa) are mid-engined cars as oppose to the rear-engined setup on the 911s. Had Ferrari put the belts on the back of the motor, that would mean the clutch assembly will have to go to the front into the cabin. So in order to fit eveything in as suggested, you will have to build an Extra-LWB car for it to retain its mid-engined setup. In Porsche 911's case, their engine sits much further back (rear-engined setup) which provides the room in front of the engine for the transmission. However, once Porsche went to mid-engined setup as in the Boxster (See link: http://www.seriouswheels.com/2000-2003/2003-Porsche-Boxster-Cutaway-1280x960.htm) You will also notice that the transmission is now at the rear with the belts in the front as well. If I am not mistaken, I think their major service is also an engine out service as well. I believe this layout holds true for today's 996-997 series as well.
  9. Air_Cooled_Nut
    Air_Cooled_Nut Formula Junior
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
  10. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Point well made. If you turned it all backwards just because of the belts (and the shift lever), what would we have?
    A Countash Diabolical Lamborghini.
    And we all know how much better THAT THING shifts and drives, and how cheap and easy it is to maintain.
  11. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,606
    Pacific NW
    Anthony C.
    Now you did it, you had to go and mention Lamborghinis, another heatly debated and beaten to death topic. This was just a belts vs. chains thread, now it will probably mutate into a "Major service on Ferraris vs. Clutch service on Lamborghinis" etc.
    The Holidays is approaching fast, can't we all just get along for a change? :)
  12. staatsof
    96,422
    Fuggetaboutitland
    Bob
    Maybe it's time for whips AND chains ... ;>)
  13. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    Love it I agree completely
  14. Finitele
    Finitele Formula 3
    Sep 26, 2007
    1,379
    DBC
    DIR
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,857
    The twilight zone
    The question is why did the not use gears?
    OK, fight amongst yourselves for a few more pages.
  16. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,285
    Illinois
    Because belts happened to be on the shelf and within reach.
  17. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    +1
  18. Motorace
    Motorace Rookie
    Jul 10, 2006
    28
    Michigan
    Dan Eastwood
    Are you sure the Daytona wasn't just 3x Fiat-124 Engines?
    (Sorry, I couldn't resist pulling someone's chain, er, I mean belt!)
    There are many compromises in every aspect of engine design, but I thought that the fact that belts are quieter was the main reason many manufacturers switched from chains to belts.
  19. mls
    mls Karting
    May 1, 2005
    225
    MC12 uses gears. Does anyone know what the FXX uses?
  20. Dapper Dan
    Dapper Dan Karting
    Jul 5, 2007
    74
    Oakland, CA
    Dan Marshall
    I find this especially strange since chains are generally the preferred cam drive for most high-perf cars, and Ferrari reverted to chains in the mid 90s. Was it just a bad engineering decision? Or do most of you feel the motivating factor was purely profit for their dealers' service departments? [/QUOTE]
    As PSk pointed out, belts actually are a performance advantage. Thier light weight gives lower enertia to help engine throttle response and acceleration, much like lightening a flywheel or other internal engine parts. And as PSk pointed out, Ferrari caved to idiotic owners who have persisted in thier lack of maintaining anything, and it was making Ferrari look like thier cars were crap.
    If your in the camp trying to find ways to get around maintainance before you even buy a Ferrari, please buy something else. Leave the 308's and other belt driven cars to the real men who know what they need, and arent so cheap or so afraid to take care of them.[/QUOTE]
    "Real Men". Oh yeh! So let me understand you best. If you are "conerned" about a high cost repair & you try to get a different point of view about this issue, you must be "cheap" or you are "afraid to take care of them"? Please let me clear the air from such a sticky comment. I've owned 2 Ferrari's and it drives (no pun intended) crazy when I take it into my local dealership and they have to have it for 2 weeks to handle a job that shouldn't take them more than a couple of days. Further, the cost to handle an 8 cyc. engine on these beauties is border line obscene! That being said, I love my cars & I can hardly wait to drive them and I can afford them without even blinking an eye. So stop this nonsense about if you have to ask you can't afford it mentality. PLEASE!!!
  21. Dapper Dan
    Dapper Dan Karting
    Jul 5, 2007
    74
    Oakland, CA
    Dan Marshall
    I have wondered this too. Sorry we got one snob that still is hung up on "if you have to ask the cost, you can't afford it" statement. The others helped to clear that question up. I hope if you haven't purchased a Ferrari that you do so. I promise you, the experience is something you can take to the grave, hopefully not too soon...
    Happy driving!
  22. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    Timing CHAINs need to be replaced as well. The Enzo chains are spec'ed to be replaced at 30,000 miles.
    aehaas
  23. Finitele
    Finitele Formula 3
    Sep 26, 2007
    1,379
    DBC
    DIR
    I think you mean Belts, like
    "and Ferrari reverted to BELTS in the mid 90s[/b]. "
  24. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Gears are for heavy duty use, for when you absolutely dont want failures. Thats why all good diesel or gas industrial engines use gears. Its why they sometimes use them in endurance racing engines. But for better acceleration and performance, belts or chains have less mass, so less enertia is required to spool up, or accelerate. Thats why Ferrari used them in F1 back in the 60's and through the 70's, purely for performance.
    The bottom line is that chains dont really last any longer than belts, but chains will give you warnings of eminent doom by making more and more noise, and most people drive them far beyond thier recommended life without major failures. But boy, when a chain breaks it will do considerably more damage, especially if it wraps up around the crank sprocket. Its not unheard of to break the block. But then if you throw a belt on a 348 or newer, it wont really matter, its gonna be awfully bad either way. I would bet if a chain let go on a F430 or an Enzo, most would shudder to see the repair estimate.
    Everything is in life is a compromise. If you want maximum reliability, you must sacrifice some performance. If you want maximum performance, you must sacrifice some reliability. Max reliability would be something like a four cylinder cast iron Cummins turbo diesel. Max performance is something like a top fuel Hemi. Hopefully Ferrari gave us something of a compromise between the two.
  25. sanimalp
    sanimalp Rookie
    Dec 28, 2007
    22
    Ft. Collins, Co
    I think my friends on honda-tech.com put it pretty eloquently: "Fast, Cheap, Reliable. you can only have 2."
