355 - Why do rear shock actuators rotate | FerrariChat
355 Why do rear shock actuators rotate
Discussion in '348/355' started by Rorie, May 31, 2025.
  1. Rorie
    Rorie Formula Junior
    Oct 2, 2007
    459
    Toronto, Canada
  2. Qavion
    Qavion F1 World Champ
    14,225
    Ian Riddell
    Perhaps the actuator is not located properly. There is a spring clip which holds it in place. Remove the spring clip and try to re-orient the actuator. Whatever you do , don't lose the clip. They have a tendency to fly off. There is a groove in which the spring clip sits (on the mount). When reinstalling, you may be able to install the clip first on the orange/red part. Then push down firmly. Sometimes they don't always lock in place properly, putting on the dash suspension light.
    I didn't realise this was even possible. I have seen broken actuators on 456M's which rotate the entire actuator when they shouldn't... so much, in fact, they twist the wiring, but I haven't heard of this on 355s.
    Thanks for the photo. I see you have a Motronic 2.7 car.
    flash32 likes this.
  3. Qavion
    14,225
    Ian Riddell
    Spare clips are available at Captain Z CNC (in the USA), but local Ferrari stockists may have them (?).
    flash32 likes this.
  4. Qavion
    14,225
    Ian Riddell
    I thought I couldn't see the spring clip on your RH actuator, but it's here:
    You'll probably have to remove the engine bay side cover to access the spring clip. If your side covers are like mine, they are held in with 3 allen headed screws of an unusual metric size.
    flash32 likes this.
  5. Rorie
    Oct 2, 2007
    459
    Toronto, Canada
    Thank you for that info. Appreciate it.
    Qavion likes this.
  6. phrogs
    phrogs F1 Veteran
    7,341
    Kzoo Michigan
    Same clip as the Corvette fx3 system
    Qavion likes this.
  7. Rorie
    Oct 2, 2007
    459
    Toronto, Canada
    I've had to remove the side covers before to charge the car.
    My mechanic said to be careful as it is easy to break the internals. He also said in his 20 years of working on F355s he has never seen this on an F355.
    So it's really a case of just unplugging the acutators and plugging them back in. But I suspect they are twisting because something is slipping.
    I feel much better about, and thank you for that info.
  8. Qavion
    14,225
    Ian Riddell
    Is the LH actuator actually locked down or will it pull right up? Does it even have a clip on it?
  9. Rorie
    Oct 2, 2007
    459
    Toronto, Canada
    Checked, LH has a clip as well. And has not twisted nearly as much as the RH one. LH is locked down. As if RH drive. I don't want to bust them so my mechanic will look at them in a few weeks. I will watch him as he does it to learn how to do myself (without breaking them).
    Qavion likes this.
  10. Qavion
    14,225
    Ian Riddell
    I don’t see how you could break them. Just see if the spring clip is in the grooves on the base, although it should be if the actuator is locked down. I wonder if the shock absorber has been installed incorrectly.
