Why Do We Have AN AC Pressure Switch | FerrariChat
Discussion in '308/328' started by Lawrence Coppari, May 18, 2022.
  1. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,191
    Kingsport, TN
    Lawrence A. Coppari
    My '87 328GTS, like others, came with a pressure switch on the receiver-dryer that prevents the compressor from running if the refrigerant exhibits pressure that is too low. The cars came with a York compressor. Our compressors are splash lubricated like a small lawnmower. The piston rings are lubed whether there is refrigerant in the system or not.
    What is the need for the switch? Can it detect if the system is overcharged?
  2. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,147
    SanFrancisco BayArea
    1983 US 308 GTS QV
    The switch opens both at a threshold low pressure and high pressure. I just replaced that switch (see this post: Air Conditioning Pressure Switch).
    The high pressure cut-off is there in case the expansion valve gets plugged and the compressor just keeps raising the pressure.
    As for why there is a low pressure cut-off, I am a little unclear too, although it means the system has lost refrigerant and is no longer holding pressure so there is no use in running the compressor.
  3. thorn
    thorn F1 Rookie Silver Subscribed
    Aug 7, 2012
    3,324
    Tallahassee, FL
    Splash characteristics aside, it makes more sense for the system to be designed with the pressure switch present - so that it will work with *any* compatible compressor, not just the York. And as noted by Brian, high pressure in the system can be a problem no matter which compressor type.
  4. Lawrence Coppari
    Apr 29, 2002
    2,191
    Kingsport, TN
    Lawrence A. Coppari
    I suspected it was a high-pressure safeguard. In their second life, some York compressors are used as air compressors. If I were replacing my pressure switch, I'd hook it up to my compressor and multimeter to check out both ends of its design capability.
  5. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,606
    California SF bay area
    Paul
    Because the refrigerant also carries the oil for the compressor.
    Albert-LP likes this.
  6. Albert-LP
    Albert-LP F1 Veteran Owner Rossa Subscribed
    Sep 1, 2010
    8,165
    around Modena, Italy
    Alberto Mantovani
    Correct: that's the reason
    Ciao
  7. Lawrence Coppari
    Apr 29, 2002
    2,191
    Kingsport, TN
    Lawrence A. Coppari
    Sorry, I cannot agree with you guys regarding needing oil in the refrigerant for a York compressor which has an oil sump. With other compressors you need it. Not so with our York compressors. I suggest you check out the attached link.
    www.jedi.com/york-air-lube/
  8. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,147
    1983 US 308 GTS QV
    None of this relates to your original question about the pressure switch, but oh well ...
    While lubrication of the crank and pistons is through a splash system, other parts of the compressor are lubricated through oil circulating with the refrigerant. There is a small port which connects the crankcase to the upper part of the York compressor. This is process is described on the "Features" page of the York Service Manual (York Compressor Service Manual.pdf)
    As noted in your Jedi.com link that you posted, a York compressor can be modified to be splash-only which is satisfactory for use as an air compressor because a little air leakage doesn't matter. The description of the modification in your link is: York Compressor Oil System Modification Page – Jedi.com (It is the link cited on your page in the bold face: "[ I’ll be updating this page eventually with updated info. Until then, check out the York oiling modification page. ]") Without that modification, oil escapes the crankcase as is also described in your links.
    The measuring of the oil level using the dipstick should be done after the system has "stabilized" as described in the "Inspection" page of the Service Manual. "Stabilized" means after oil has distributed itself through the small port. The "stabilized" level should be at least 6 oz. And woe betide thee should ye openeth the oil fill plug when the system is pressurized.
    I just completed refurbishing my system yesterday. (Among many other things) I flushed the entire system with Mastercool AC Flush Solvent, filled the compressor with 11.5 oz of Supercool Synthetic Ester Oil and recharged the system.
