Why Does Brembo only Offer Brake kit for 77-84 308? | FerrariChat
Discussion in 'Technical Q&A' started by 308dino74, Feb 28, 2006.
  1. 308dino74
    308dino74 Rookie
    Nov 15, 2005
    16
    Hello....
    Does anybody have an idea why there kit will only fit 77-84 308 cars and not the early 74-76 GT4 cars. I was under the impression that the braking systems were identical. I actually called Brembo and they were not sure either. They suggested that it may be because of different brake lines or sterering knuckle.
    Has anyone installed the kit and had it work no problem?
    Thanks.......
  2. classic308
    classic308 F1 Veteran
    Jan 9, 2004
    6,820
    Westchester, NY
    Paul
    What about 77+ Dinos? Will they fit?
  3. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Call the Eric or his partner at FChat sponsor www.************ -- he used to work for Brembo as an engineer and actually designed the kit that Brembo sells. He now makes a competitive kit through Girodisc, but he can probably answer your question.
  4. 308dino74
    308dino74 Rookie
    Nov 15, 2005
    16
    I actually have called and Martin at Girodisc has never installed the kit on an 308 gt4. I actually purchased the rear kit from them and it fits perfectly. My concern is that I am being told by many people that the front kit will not work but nobody has been able to tell me why exactly.
    Thanks.....
  5. 308dino74
    308dino74 Rookie
    Nov 15, 2005
    16
    I actually want to install the Girodisc setup....i asked about the brembo kit only because I figured there would be more people out there who have information on that kit..
  6. 308dino74
    308dino74 Rookie
    Nov 15, 2005
    16
    I seem to have received a good answer on this question. The only difference in the 308gt4 brakes and the later 308 brakes is the length of the brake lines.
    Hope this helps other 308 gt4 owners....
  7. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    From my info, even the brake lines are identical, I stock steel braided lines that fit all models, and have fitted enought sets to verify that this is the case!!
    GT4's have little scoops on the brake backing plates, that sort of line up with a brake duct fitted into the wheel arch.
    These are a good retro fit on 308's too, although I think removing the whole backing plate entirely helps cooling more.
  8. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,321
    QV London do a kit for GT4s using a modified 355 setup I believe.
    I.
