Why does "everyone" prefer the 458 over the 488? | Page 11 | FerrariChat
Discussion in '458 Italia/488/F8' started by amazingtrails, May 28, 2025.
  1. KnifeEdge2k1
    KnifeEdge2k1 Formula Junior
    Jun 1, 2022
    407
    Dominic Leung
    That's the thing though, a 3.9l on twin parallel turbos is equivalent to a 2liter on a single turbo. This is mechanically identical.
    Yeah sure, but turbo manufacturers, automobile manufacturers, etc. all of them will tell you the advances are in metallurgical and geometry, not in "using two turbos instead of one" especially when in multi bank engines using two turbos is usually easier to do than using a single for packaging (with or without cross bank charging). You can literally just look at a turbo from the 80s and one from post 2000s and see how much more complex the blade geometry is. Twin scroll turbos and VTG also plays a role but the latter is still relatively rare while the former is quite common.
    BMW turbo sixes are probably the best example of a large displacement single turbo ICE. The N54 used twin parallel setup and was abandoned for a single twin-scroll setup in the N55 and all their turbo sixes since.
    Porsche Boxster/Cayman uses a single turbo with a 2.5L flat 4 and the new GTS uses a single turbo as well (this is a bit of an unfair comparison given that's using electric hybrid/split turbo like that used in F1)
    Does the 3.9l on two turbos work better than it would on a single turbo ? absolutely it does but it would be disingenuous to say that this is the reason why it's good. V8s lend themselves to using a single turbo on each bank, a flat plane crank v8 even more so. So Ferrari using twin turbos on the 488 isn't so much something that should be lauded as something that should be EXPECTED. That makes it NOT praiseworthy. The default should not be praised.
    The "lore" behind twin-turbos all pretty much came about from small displacement engines using sequential turbos (small+big). \
    V8s, V10s, V12s naturally lend themselves to using more than one turbo, it would be "strange" to see them using anything less than two.
    4pots lend themselves to using a single turbo, it would be "strange" to see them using more than 1, which is why a twin-turbo 4 is "interesting"/"cool" because it's not obvious, it signifies the engineers/designers are placing a strong desire for both high end output AND response (generally a twin turbo 4 is going to be of the big + small variety)
    6's are in a weird middle ground where it's conceivable to run either the twin parallel or big+small variety and for it to legitimately make sense, in a multi bank (v or flat) probably a twin parallel makes sense and a big+small wouldnt (for packaging) and for an inline 6, anything goes (although with modern turbos you can still get very good response with good top end without having to use a twin setup as every single BMW since the N54 has shown)
  2. vjd3
    vjd3 F1 Rookie
    2,834
    Massachusetts
    Vic
    I suspect there are fewer DCT issues on the 458/488 cars because the California and California T are more apt to have higher mileage as they are GT cars and probably get driven more than weekend blasts in the midengine car. I'm not sure of the sales numbers but I would guess they sold more California than 458s/488s overall.
    Keep in mind that the sensor issue (early wiring harness in particular) is not the inherent flaw that lurks in all the Ferraris with that gearbox. Although a sensor can go bad for other reasons, which is why it makes sense to replace them all whenever the gearbox is opened.
    Informative video from Micah at the Hollywood Mechanic (and he has a much more in depth one as well on his channel) ...
    Irregardless, the gearbox issue is just as apt to strike any Ferrari from that era so it's not a consideration between the two unless it's a very early 458 before they changed the clips on the internal wiring.
    mdrums likes this.
  3. KnifeEdge2k1
    Jun 1, 2022
    407
    Dominic Leung
    That leak seems to be a different issue to the dreaded (losing an entire 'bank' of gears) but yeah, it wouldn't be a ferrari if it didn't have a hidden time bomb "somewhere" right ?
  4. Twosherpaz
    Twosherpaz Formula Junior
    Feb 25, 2014
    946
    Thermal, CA
    Private
    You know the reason, blah blah, last NA is not trivial.
    I do grab the key more often for the Pista than the Speciale largely due to speed/torque. Not so much the case on the 296 but I think that is because the seat just doesn’t treat my back so well.
    Speciale A, Pista Pilota, Speciale, Pista spider, Pista are the top five collectibles from 458/488 era. F8 only true collectible is SP48 Unica.
    Ash Patel and MANDALAY like this.
  5. MacNugget
    MacNugget Formula Junior
    612
    Tejas Hill Country
    This invites the question -- what percentage of the marketplace is shopping for a "collectable" vs shopping for a "car"?
    mdrums and up4speed like this.
  6. dustman
    dustman F1 World Champ
    11,687
    At the right price, everyone.
    Ash Patel likes this.
  7. BuyHighSellLow
    BuyHighSellLow Formula Junior
    Mar 18, 2025
    293
    Alberta Canada
    Looks like a Ferrari on top and a Nissan on bottom
    ACSATCO likes this.
  8. dustman
    11,687
  9. MacNugget
    612
    Tejas Hill Country
    I'm not sure I follow. What do you mean?
  10. dustman
    11,687
    It’s all good.
    Exiting this thread.
    Eilig likes this.
  11. Eilig
    Eilig F1 Rookie
    4,272
    Tänzelndes Pferd
    Me too. Talk about beating a dead horse (of the turbo persuasion)
  12. Ash Patel
    Ash Patel Formula Junior
    Dec 12, 2015
    549
    Stockholm, Sweden
    I’ve owned several 458s and would never go back. The styling hasn’t aged well, and it’s slow. Get the 488—it looks much sharper and is faster, even though some people claim the opposite, which is hilarious.
    Mk23, LVP488, MANDALAY and 6 others like this.
  13. d16dcoe45
    d16dcoe45 Rookie
    Aug 4, 2024
    24
    Tarrytown NY
    Jay Justin Lestingi
    Wow the blinders are REALLY on
  14. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,528
    Southlake, TX
    Rob Lay
    OK big guy, tell me how a Ferrari 458 is new and specifically what is better about a C8?
  15. Gattiman
    Gattiman Rookie
    Jul 12, 2025
    1
    Allen Drewe
    I like the 488 better but I’m a younger, speed matters kind of guy. Not that the 488 is king of the road but the 458 is slow slow.
  16. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    C8 is about as cool as a 83 vette
    BuyHighSellLow likes this.
  17. Eric C
    11,136
    St. Louis, MO
    Eric
    In stock form, I think 488 looks better. Throw some mods at it and its anyone's game.
  18. BuyHighSellLow
    Mar 18, 2025
    293
    Alberta Canada
    My favorite year corvette, hands down.
    LVP488 and Eric C like this.
  19. Eric C
    11,136
    St. Louis, MO
    Eric
    Let me know when they start making Grammy award.Winning the songs about the trash 458.
  20. Eilig
    Eilig F1 Rookie
    4,272
    Tänzelndes Pferd
  21. Kruegmeister
    Kruegmeister Formula Junior
    523
    Michigan
    Kruegmeister
    I guess I don't see it as difficult to get Torque out of my 458... 561 vs 398 is more. But my Tesla Model S Ludicrous+ had more than both, but that was not engaging. Throws you back, but that's about it
    mdrums likes this.
  22. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,790
    AUSTRALIA
    ANGELO
    I don't associate Electric with engaging.
    mdrums and blkdiablo33 like this.
  23. AhmetUz
    AhmetUz Karting
    Aug 11, 2022
    160
    #273 AhmetUz, Aug 15, 2025
    This is actually a topic that's debated from time to time. I've driven both cars numerous times, and I evaluate them completely objectively (except for the design). What matters here is your perception of the car. Some people always think modern cars are faster, and that feels good. Others prefer a more refined driving experience, etc. I think the situation is completely different here. The 458 was a major revolution when it first came out, ushering in a new era. In fact, many authorities said it was a car ahead of its time, which I agree with. Dual clutch transmission, much more advanced electronics, a smooth ride, etc. I think the models that followed never experienced such a revolution. For example, when I sat in the 488 after the 458, I could feel it was a new model, but I didn't say "wow." Moreover, as I've said before, the car's high torque can be a nuisance, especially if you're not on very good asphalt, with sudden bursts of torque, and this (in my opinion) disrupts the flow of driving. Yes, it accelerates effortlessly, but (again, in my opinion) it revs too quickly. Also, no matter what anyone says, I don't like hearing the turbo whistle in a Ferrari.
    For example, I know some very experienced Ferrari owners (people who have owned several different models for a long time, are deeply familiar with the brand and its culture, have connections within Ferrari management, and have participated in numerous international events). Some of them, having owned a 458 and other models, eagerly awaited the 488's release, but after a test drive, they didn't buy it and instead moved on to other models, and sometimes even other brands. I'm writing this to express that some of the criticisms about the 488 may be justified, and that such opinions exist.
    There's also the design, which is a subjective opinion. Some may like the 488's design more, but the 458 seems to me to be a more thoroughbred car with much cleaner lines. As I said, when I drove both cars, I didn't feel like there was a huge difference in the underlying technology. (Perhaps because the 458 still feels modern and up-to-date to me today.) Some people might disagree, but models like the 458 are very rare within the brand, and perhaps that's why this car is still so beloved. Ultimately, both are quite successful Ferrari models, but I prefer the 458 regardless of price.
  24. Eric C
    11,136
    St. Louis, MO
    Eric
    Great post.
  25. Lucky275
    Lucky275 Rookie
    Apr 21, 2025
    33
    greg reeder
    I love the bathroom acoustics or maybe he's rapping into the turbos.
