Why I don't like timing belts ... | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by PSk, Aug 8, 2010.
  1. wingfeather
    wingfeather F1 Rookie
    Feb 1, 2007
    3,653
    rock bottom
    I went through the same thing!
  2. ferraripete
    ferraripete F1 World Champ
    hear hear! pun intended!!! :)
  3. BigTex
    79,418
    Houston, Texas
    Bubba
    We had a solid gear set option on the Pontiac big blocks, to replace the chain.
    Never tried it myself. It did increase the engine noise, I'd heard...
    I was too busy trying to get the piece of rope that served as the rear main crank seal, to quit dripping oil onto Mom's driveway......
    Compared to pulling the water pump, aluminum housing and timing chain, Ferrari belts are EASY!!
    The Gulf Coast tap water always dissolved the aluminum of the cover behind the pump, letting water right into the oil section of the block.
    Those 400CI motors were firebreathers, the largest set of valves touched each other, edge to edge.
  4. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    #54 PSk, Aug 28, 2010
    Simply incorrect.
    The belt is under more tension from the crank (the driver) too the pulleys (the driven) that the crank is pulling around. From the last pulley that it turns back to the crank it is "not under tension". This is why you adjust the tensioners to take up this slack, and that is why the tensioner is always positioned after the last driven pulley and before the driver.
    Without the tensioner they (belt or chain) would behave just like a m/c chain that drives the rear wheel and flap about.
    Pete
  5. Future ferrari collector
    Oct 12, 2006
    1,795
    Don't know of anyone who has done it but I would be most interested if it can be done. But at what cost?
  6. wingfeather
    Feb 1, 2007
    3,653
    rock bottom
    Chains break, too.
