News
360 Why some 360 burn ?
Discussion in '360/430' started by concetti, Mar 29, 2020.
  1. concetti
    concetti Rookie
    Apr 10, 2018
    13
    CONCETTI Michel
    Hi. Someone knows why some 360 burn? what is the origin? what pieces should be changed regularly or controlled?
  3. one4torque
    one4torque Formula 3
    May 20, 2018
    2,008
    Houston
    One4torque
    Inspect fuel system from pump to injectors—-
    cracked brittle plastic fuel pump hats/mount rings
    Cracked brittle fuel lines
    Chaffing fuel lines
    Loose leaking fittings
    Check ps fluid system
    Not sure about how common elec fires?
    24000rpm likes this.
  4. vrsurgeon
    vrsurgeon F1 World Champ
    13,752
    Charleston, SC
    Curt
    Usually shoddy repair, not fitting fuel bits together properly. Other times its old plastic that degrades on the fuel pumps due to the heat.. inexperienced owner ignores the fuel smell and then a high pressure hose breaks off spilling fuel into the engine compartment on the hot cats.
    Finally, sometimes it's just because a car wants out of this world. Owner is an idiot and doesn't treat her right. She just decides to self-immolate.
    02360spider, kes7u, Dewinator and 3 others like this.
  5. vrsurgeon
    13,752
    Charleston, SC
    Curt
    As an aside.. MANY cars catch fire and burn. MANY cars get stupid hello kitty wraps and worse. It's HUNDREDS or THOUSANDS a year worldwide.
    The reason "so many" Ferrari's burn is its sensational. If a 60's american muscle car or a Kia spurts some smoke on the side of the road, you say "oh that sucks" and you go back to playing with the GPS or Radio and drive on. When it's a Ferrari, like a beautiful woman smearing herself with paint or worse, you take notice. I would venture to say that given the production numbers, Ferrari actually has a LOWER rate of fires than many other marques. The only reason Jalopnik bothers to write about it is because it's not mom and dads Kia or Honda that the reader is commuting to school with.
    Need4Spd and SoftwareDrone like this.
  6. one4torque
    May 20, 2018
    2,008
    Houston
    One4torque
    While these below problems are not specific to a ferrari.... it is the proximity of these bits above the hot exhaust that escalates what is normally a small problem to a car-b-que.
    "Inspect fuel system from pump to injectors—-
    Chaffing fuel lines
    Loose leaking fittings"
    brookliner7 likes this.
  8. concetti
    concetti Rookie
    Apr 10, 2018
    13
    CONCETTI Michel
    ok thanks you. i will check all this parts and change the pump
  9. albkid
    albkid Formula Junior
    Jul 1, 2016
    317
    Jim
    There are two fuel pumps in a 360 and are expensive. As others have suggested, there are a number of possible failure points, and you may or may not have one or some. An experienced mechanic can check the fuel system and give you the peace of mind you seek.
