Why TDC on belt change | FerrariChat
Discussion in '308/328' started by Steve King, Feb 26, 2008.
  1. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I usually follow the standard proceedure of setting the timing mark on TDC with the piston in the compression stroke but have wondered why you need to do this if you have the cams locked and you are only doing a belt change. So if you are not pulling the cam covers and you know that the engine had been in time why not just mark the belt and pulleys as we normally do and just change the belts. I have to align all of the marks when I do my wife's Volvo but Volvo marks the timing belt with the locations where it lines up with the pulleys. Ferrari does not so usually we make our own. Any thoughts on this.
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,844
    Cerritos, CA.
    Steve, I suppose you really don't have to align the markers as long as none of the pulley/gears move when removing the old belt
    and it stay exactly where they are when installing the new belt.
  3. blainewest
    blainewest Formula Junior
    Aug 26, 2005
    729
    Kelowna, BC
    Blaine W
    I don't think you need to if all you're doing is swaping belts. You'd just need to mark each pulley (all three per bank) with a corresponding mark to the old belt, then accurately transfer the mark on the old belt to the new belt, install new belt by matching up the marks, release tensioner, hand turn 2-3 revolutions just to be sure valves and pistons are not playing tag, tighten tensioner, button up. I think the TDC thing is important to see where your cam marks line up and if you're going to degree the cams.
    Having said all that I TDC'd mine when I changed them.
  4. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    I have a chain, but if I was doing a 7 year belt change (like I would if I had such a car) I'd also be checking the cam timing just to be thorough. So as a matter of course I'd have the #1 cylinder at TDC on the power stroke before I dug in. If you do 3 year changes I seriously doubt you need to worry about it every time. Like valve clearances....check them, but a broken in engine will not need adjustments every 3-5 years, or more. Mine were spot on after 7 years....YMMV but probably not.
    Ken
  5. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    Steve,
    I think the real issue is what do you do if one or more of the cams move while you are doing the job? If you don't have the flywheel and pistons at TDC/compression stroke, you have no prayer of realigning everything quickly and easily. Having the engine at TDC/compression allows you in a pinch to reset the cams based on the factory marks and then go from there. IMHO, taking a chance and depending on the cam lock as your only backup is taking a big chance. I'd rather have the engine set in the right position and know that if I have a problem, I can easily fix it.
    Regards,
    Steve
  6. SonomaRik
    SonomaRik F1 Veteran
    Why would you not want to do the full job?
    check valve clearances tensions etc. etc. Seems just freezing the cams for a belt change with engine out isn't worth it on a 348 [sorry, but the Mondial T is always stuck in the Mondial section when it should always be included in the 348 section].
  7. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    Ah, "engine out". That's a whole different ballgame!
    Ken
  8. SonomaRik
    I know, but like I said, when the Mondial T is in a lump with ALL 70-80's Mondials then I have no choice: Mondial T's are to be in the 348 section period.
    They have more in common with a 348 in mechanics, suspension, trany, even some interior than older 3x8 or [non T] Mondials.
    but I dribble on such......
    Still wondering why someone might not want to check all components while belt was off, to make sure. Or is the goal only to rely that all is well, and replace the belt.
  9. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,766
    US of A
    Michael
    I agree.
  10. FasterIsBetter
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    +1. When I had my 308 engine out, I did the whole thing. If I just wanted to change the belts with the engine still in the car, I'd use the cam lock. With the engine out, it is silly not to do the whole job.
  11. Steve King
    Feb 15, 2001
    4,367
    NY
    Sonomarik I'm just doing the regular belt and tensioner change. 10K miles but 5 years since last done. Valves and seals done last time so there is no problem. If I needed to pull the engine I would do everything while it was out. My main focus is to just get this done and then start the Sanden AC conversion.
  12. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    The valves just don't need adjustment that often. Since most of us don't drive anywhere near enough to need to check the valve clearance at every belt change, it doesn't make sense to tear open an engine that isn't leaking and doesn't need cam seals and cam cover gaskets, etc. just because the belt is due for a change due to age. As long as you know your timing is right and valves were checked during a previous major not too long ago, I see no reason not to just do the belt change. It's better than NOT doing the belt change!
    Birdman
