why won't V1 plug stay plugged in on CS? | FerrariChat
Discussion in '360/430' started by ben, lj, Nov 29, 2004.
  1. ben, lj
    ben, lj Formula Junior
    Aug 23, 2004
    594
    anyone know more about any special adapter, etc to get the V1 to actually stay plugged into the CS power supply?
  2. F360CS
    F360CS Karting
    Aug 14, 2004
    62
    MARLBORO, NEW JERSEY
    ALLEN
    i have the same problem, i have to run the cord down under the seat bracket to keep it in place, an adapter would be great
  3. 4i2fly
    4i2fly Formula 3
    Apr 16, 2004
    1,333
    SF, Bay Area
    I think it is easier to just hard wire it to the dome light and forget about it. There is even a thread on "how to" for the 360 if I remember correctly.
  4. UroTrash
    Jan 20, 2004
    40,487
    Purgatory
    Clifford Gunboat
    Now THAT is massive acceleration! :)
  5. FarmerDave
    FarmerDave F1 World Champ
    Jul 26, 2004
    15,782
    IgnoranteWest
    for the CS-challenged indviduals like me, what is the V1 plug, where is it, what function does it perform?
  6. bboxer
    bboxer Formula Junior
    Aug 6, 2001
    612
    Same problem with 360. Easy solution (at least a year or so ago): Valentine had a small thin plastic sleeve that fits on the V1 plug and makes for a snugger fit. Check with Valentine.
  7. UroTrash
    Jan 20, 2004
    40,487
    Purgatory
    Clifford Gunboat
    You know I could use one of those on my skinny little... oh never mind.
  8. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    somebody get urotrash a day job ;)
    mine does the same, and the silly plastic sleeve thingy is too big to fit in the lighter socket.
    i'm gonna have it hardwired shortly.
    doody.
  9. f355spider
    f355spider F1 World Champ
    18,044
    Agreed, call Valentine, this is not a new problem for some imported cars. They will have a fix.
    Dave
  10. India Whiskey Charlie
    India Whiskey Charlie Formula Junior
    May 24, 2001
    554
    Way Out West
    Are you using the coiled cord? If so, it is too short and tends to pull the plug out. I am using the longer flat cord and it stays just fine. No adapters are needed.
  11. mbarr
    mbarr Karting
    234
    Texas
    Hardwired is the way to go. Might cost you $50 - $100.
  12. ben, lj
    Aug 23, 2004
    594
    No, I went to the flat cord after having the coiled one pop out in two seconds. Sean R. (you probably remember him from your neck of the woods) hardwired my F150 and I'll order up some more kits for the rest of the cars and have him do the CS if that is the only solution. The sucky thing about hardwiring is a) it should be on the passenger side since I usually drive crazy by myself and don't need a torpedo at my head b) you can't indiscretely pull it down and hide it if a cop gets you and c) you must have the remote display or you can't see it on the driver side.
  13. FarmerDave
    Jul 26, 2004
    15,782
    IgnoranteWest
    Duh. Figured it out for myself.
  14. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    Get the battery-powered Escort Solo II, it was Autoweek's pick of the detectors a few weeks ago. I've been happy with mine.
    Gary
  15. ben, lj
    Aug 23, 2004
    594
    I went through a short Solo phase but outgrew it. Escort used to be IT until they let Valentine leave to start up his own firm. The battery powered radars are not as strong as DC powered ones.
  16. GoodWood
    GoodWood Formula Junior
    Oct 2, 2004
    351
    SE Florida/Indiana
    Steve
    position, does it? At least it didn't for my Porsche or Audi. It merely provides a constant on, (with ignition), power supply originating from the dome light. Why would you have to relocate it from it's current position if it was hardwired? Also, from my experience, it's just as easy to remove if need be.
  17. watt
    watt Formula 3
    Jun 17, 2004
    2,253
    Northern Rocky Mountains
    Giuseppe T Hemingway
    i use the stylish, yet effective piece of duct tape.
  18. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    i think this makes it 100% official: watt is a nutcase ;)
    doody.
  19. watt
    watt Formula 3
    Jun 17, 2004
    2,253
    doo-ron,
    how dare you??? i use a splitter for the V1 and the cell cord, and put one wrap of tape around the splitter as it hits the lighter receptacle... when Jack sends his guy over to put in a plug, i'll be glad... i had one put in a TT once.
    Jack told me one is not allowed to have leaves or dirt from your soccer playing son in the car, either .. must be a F thing?
    btw, did you know in LA mon, customers cancel their F service appt.s if it rains???? cars made of sugar, mon. that would never happen in Boston, right mon???????
  20. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    lol watt! i'll have to take some snaps of my leaf-ridden, filthy CS for you! i even have muddy kitty cat pawprints running up the hood :)
    snow or ice on the roads keep my toys in the garage, but that's about it. life is too short!
    doody.
  21. ben, lj
    Aug 23, 2004
    594
    because i keep it on the windshield between the passengers in the middle but clip it to a visor when hardwired so a wire isn't constantly on the dash.
    did you get your car?
  22. ay360
    ay360 Rookie
    Apr 2, 2005
    2
    naperville, IL
    asad yusuf
    there is a piece you can get that looks like a little sleeve that goes over the plug with inlets for the side metal pieces. it widers the diameter of the plug to make it a more snug fit. try contacting valentine because my radar came with the extra piece
  23. Brian C. Stradale
    Brian C. Stradale F1 Rookie
    Mar 17, 2002
    3,615
    Dallas, TX, USA
    #23 Brian C. Stradale, Apr 12, 2005
    1. No annoying cords to deal with (or duct tape!)
    2. Never falls out leaving you unprotected
    3. No need to find it and stick it back in while at full speed (no dirty jokes, please)
    4. Never drains your battery; turns off with the ignition
    5. Nestled between the headliner and mirror, it is fairly stealthy
    6. As high as possible, it is best positioned to see those signals coming over the next hill
    And its easy/cheap... Just Do It! Next time your car is at your Ferrari shop, just hand them the hardwire kit, tell them to run it between the windshield and the headliner to the SWITCHED wire in the dome light... they might not even charge you, its that easy!
  24. marknkidz
    marknkidz Formula 3
    1,327
    so cal
    mark
    Brian, are you sure about that angle you have it mounted? It sure doesnt look like it is correct, for the best possible performance of the V1. I like that it is up and out of the way, how long have you had it like that and is it performing properly?
  25. ben, lj
    Aug 23, 2004
    594
    i think he must be trying to detect radar from airplanes :)
