Wicked brake squeal...but pads look great. Any pointers? | FerrariChat
Discussion in '348/355' started by ready321now, Nov 11, 2014.
  1. ready321now
    ready321now Formula Junior
    Jan 5, 2013
    493
    New Jersey
    Yeah @ this point it's actually getting embarrassing. I have squeal on at least two possibly three wheels. It starts when the pads warm up a little bit and it goes away when the pads are hot . How do I eliminate this squeal????? Not sure if my brakes are stock or aftermarket but the pads look great. Tons of pad left.
    Thanks all.
  2. plugzit
    plugzit F1 Veteran
    7,789
    Redondo Beach, CA
    Bruce Bogart
    Some pads are directional. Check the back of the pads on one of the squealers for an arrow.
    Do the 7 at 70 exercise, stopping quickly 7 times from 70 mph.
    I'm sure you'll get many other good suggestions.
  3. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Your an animal :)
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,741
    I tend to use 90-30 MPH, but the drift is the same.
    If you have the windows down, you can smell when the pads are sufficiently hot.
  5. bigblock737
    bigblock737 Formula Junior
    Dec 19, 2013
    711
    Germany
    Andy B.
    Wash the rotors with warm water and a few drops of dish detergent, then rinse thoroughly. Sounds odd, but works ;)
  6. ClydeM
    ClydeM F1 World Champ
    12,056
    Wayne, NJ
    Clyde E. McMurdy
    I used most of the tricks here with dealer installed pads. The squeal might go away for a short time, but would return with a vengeance.
    Switched to Porterfield pads recommended here. That did the trick. Every so often I'll get a chirp, but a quick hard brake like when you bed the pads does the trick.
    brent Lachelt likes this.
  7. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    #7 lotusk, Nov 12, 2014
  8. junglistluder
    junglistluder F1 Rookie
    Mar 23, 2007
    3,624
    VA
    Brendan
    I would remove the pads and put some "anti squeal" spray on the back of them then reinstall. It's basically a sticky coating that prevents the pads from vibrating. I always do this when changing pads and never have any squeal issues.
  9. judd10
    judd10 Formula Junior
    485
    Seattle, WA
    I switched to the softer Porterfield pads and the squeals went away. Great pads IMO.
  10. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    What is the dust factor of the Porterfields? I know about the "anti squeal" stuff, but my shop says it is ineffective with the stock 355 pads, and the squeal always returns.
  11. WATSON
    23,879
    WI
    Really? I put CRC Brake Quiet on mine 4 years ago...still waiting for the squeak to return.
    As I understand it, the squeal comes from the back of the pad against the brake pistons. Certainly a perfectly bedded pad with rotor will not have any chatter to cause the squeak.
    But if it is not perfect, putting a shim or energy absorbing material between the back of the pad & the piston should stop the squeak....maybe just long enough to let the pad properly bed to the rotor.
  12. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    Depends on the porterfields you use, but generally they are quiet dusty.
    The CRC Brake Quiet Watson mentions helps quite a bit.
    Also note, track pads, when they aren't up to temp, they'll squeak quite loud, but once up to temp and slowing you down at high speeds, there will be no squeaking.
